Old 03-09-2023, 07:07 PM
Masato Takasawa Masato Takasawa is offline
Default How many channels of Dubber are required for the Dolby Atmos System?
How many channels of Dubber machines do I need to build a Dolby Atmos system?
What kind of stems will be recorded?
Content will be produced movies and Netflix.
Old 03-09-2023, 09:09 PM
its2loud its2loud is offline
Default Re: How many channels of Dubber are required for the Dolby Atmos System?
There is no simple answer to this question.
The number of channels is determined by how many beds and object you have for any particular project.
You should design you dubber to allow the maximum amount of channels the Dolby Renderer can handle which would be up to 128 channels. Unless you’re planning on recording other live re-renders to your dubber as well. In which case you’re going to want to have more.
Old 03-10-2023, 12:32 AM
Is it common for the Dubber machine to record not only each 7.1.4 stem and rerenders returning from the Renderer, but also the objects sent from each machine to the Renderer?
Old 03-10-2023, 02:24 AM
Yes, the Dubber records all beds and objects prior to going to the Renderer. The Dubber feeds the beds and objects to the Renderer for monitoring while mixing and then eventually recording into the Renderer.
The usual style for mixing with a Dubber is to use PEC/DIR.
Old 03-23-2023, 08:35 AM
Steven1145 Steven1145 is offline
Start at 128 channels, just for recording what could be going into the RMU. I say could because some Atmos mixes will be simpler than others and won't use all the channels. On a crazy action or animation movie on the other hand...
Then if you need to record re-renders in the same pass as the main mix, then add another 64 channels (basically a PT HDX3 setup).
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
HTML code is On
Before Dolby Atmos there was Ford Atmos gives Pro Tools 0 12-31-2022 02:12 PM
Is there a way to use a 7.2.4 Dolby Atmos home theater as a Pro Tools Dolby Atmos mix Focuret Pro Tools HDX & HD Native Systems (Mac) 19 09-14-2021 08:52 AM
Is there a way to expand HD Omni to have 13 channels (7.2.4) for Dolby Atmos mixing? Focuret Pro Tools HDX & HD Native Systems (Mac) 21 09-08-2021 05:20 PM
FS: Dolby 430 Dialogue Noise Suppressor System 2 channels kaioflex Buy & Sell 0 06-29-2021 03:30 AM
Dolby Atmos - Do I need SRC? budster Post - Surround - Video 4 03-24-2015 10:25 AM
