Old 07-08-2021, 09:50 PM
BScout BScout is offline
Default Re: D COMMAND Custom Faders "Groups" question
Originally Posted by LDS View Post
Old thread, but thanks for the video Andy!
Am I right in thinking that custom fader groups on the D Command (rather than from Pro Tools) is only possible when you have a main unit plus a fader unit to select your channels?
Yes. ICON (d-command, d-control) groups save with the session but are only recallable/usable from those surfaces. And only created there.
Old 07-08-2021, 10:12 PM
LDS LDS is offline
Sure, I get that bit. Is it possible to assign faders to a custom group without a fader pack though? With just a main unit, it seems once you are in the custom group mapping, there are no channels with associated select buttons to press like is referenced in the manual and in the videos.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 07-08-2021, 11:39 PM
Yes, the Main Unit's faders can be assigned to create custom groups. You just need to set the custom fader bank size smaller than 8 (which means you set it to 4; only option smaller than 8.) Then you have 4 channels that you can select from.
Old 07-09-2021, 12:15 AM
LDS LDS is offline
That's great. Thanks BScout!
Old 07-09-2021, 04:15 AM
[email protected] sleshnyc@gmail.com is offline
no but you have to start with a 4 fader custom group. as a workaround you can create custom 'groups' in pro tools, then call up that group. Not a custom fader group. a custom mix group. Or of course you can assign to a vca and spill that vca. I do with you could spill folders, but alas, no
  #16
Old 07-10-2021, 06:09 PM
LDS LDS is offline
Thanks guys. Switching between 4 and 8 custom faders does the trick, though I should look into adding a fader pack.
  #17
Old 07-20-2021, 12:17 AM
martthie_08 martthie_08 is offline
bit late to the party, but I use the main unit by itself too and find it helps to put the "CF Grp" preference in the "User" panel for quick & easy access.
I also have the "Faders" preference in there, which is handy for mixdowns or if clients are in the room
  #18
Old 07-20-2021, 10:19 PM
Led Led is offline
I'm a bit late to the party too, but you can have 8 fader custom groups with just a main unit, set the CF Grp Preference to 'Min 8" and the CF Jus pref to Left, and it will fill the group from left to right, with the number of faders reducing till you only have the far right fader to make your last selection to add. So you have to nudge around until the last channel you want to add pops up on fader 8.
  #19
Old 07-21-2021, 08:47 AM
Postmh Postmh is offline
On the custom fader type selector, the bottom button in the middle.. will cycle through the groups.
Hope this helps.
Unable to view edit/mix groups with custom faders Matt82au ICON & C|24 4 03-08-2018 11:30 PM
12.8 "clip groups with embedded fades not supported for fade command" Sean Russell Pro Tools 12 9 07-17-2017 09:04 AM
Any news on adding faders to custom groups more easily? Drew Mazurek ICON & C|24 19 06-08-2012 02:48 PM
Question about "Groups" Xavior Tips & Tricks 7 09-15-2008 05:42 PM
D-Control Display Groups On Custom Faders? GlennR01 ICON & C|24 7 03-09-2007 07:54 AM
