Old 09-28-2018, 07:56 AM
daeron80 daeron80 is offline
Default Re: 2018.7 Glitches on Windows 10 (FIXED)
[QUOTE=kw88keys;2500204Well...I updated my NVidia driver and still get the problem as described above from the original post. I assume at this point that this is associated with Windows 7 which I want to stay with. Went back to 2018.4 and all works well. Staying with this for now.[/QUOTE]
Yes, 2018.4 is the last one that is compatible with Win7. I'm going to go ahead and step up to Win10, even though I hate to, because 2018.7 is just brilliant. It's a milestone for PT software, in my opinion.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 09-28-2018, 09:21 AM
producedbybond's Avatar
producedbybond producedbybond is offline
The problems described with 2018.7 are not isolated to Win7. Both of my setups are Win10.
Old 10-19-2018, 08:53 AM
kw88keys kw88keys is offline
Revisiting this glitch. Has anyone updated to 2018.10 to see if this has solved the problem?
Old 10-21-2018, 09:48 PM
I just installed 2018.10, and did a quick test. Does not appear to have fixed any of these problems.
Old 10-21-2018, 11:47 PM
onosendai onosendai is offline
Which build of windows are you running?
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802
  #16
Old 10-22-2018, 11:16 AM
Windows 10 64 bit Build 17134.
Really need them to sort this stuff out. These bugs make working in PT very challenging, especially the lack of a visual numeric display when altering autotmation. Switching back to being exclusively Cubase might have to be in my near future.
  #17
Old 10-22-2018, 03:11 PM
I'm running an older build and not I'm getting the same problems and my gfx card is an 970 so its almost identical to yours. I know right now that a lot of windows users with intel onboard graphics are having some pretty problematic graphics issues due to the recent win update and some were able to solve it by manually fethcing and installing the intel drivers.
  #18
Old 12-16-2018, 07:37 PM
Originally Posted by kw88keys View Post
From the original post:
2 - In the EDIT window, when dragging a clip, it moves down, then jumps back up to the correct track when dropped
SO I updated to 2018.10 and still experience this with Windows 7. I assume at this point that this is not considered an error and just a byproduct of retaining Windows 7. As posted in the quote above - back to 2018.4
  #19
Old 03-24-2019, 08:23 AM
amishsixstringer amishsixstringer is offline
Have you had any luck with this? I'm getting the EXACT same issues as you. Windows 10.
PT 18.12.0
NVIDEA GTX 750Ti
intel i7
Trashed all pt prefs. This happens in all my sessions, but if I copy a session and transport it to a different machine the problem doesn't follow the session. Device manager says all my drivers are current. Pulling my hair out.
Neil
  #20
Old 03-24-2019, 03:54 PM
PT 18.12.0
NVIDEA GTX 750Ti
intel i7
Neil
There is a configuration issue or another piece of software running that is causing PT to act like this. Far too many people have no issues like this whatsoever. Do you have the bios configured properly, possible anti virus or other background running software??
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Poor graphics PT 2018.4 on Windows 10 Pro Gaston69 Windows 10 07-13-2018 10:06 AM
Weird UI glitches in 2018.3 on macOS 10.13.3 Chingy Pro Tools 2018 6 04-06-2018 05:17 AM
Graphics glitches with 2 monitor setup in 12.7 bashville Pro Tools 12 22 05-04-2017 03:47 AM
Graphics Glitches PT HD 11.3.2 on Yosemite steveG Pro Tools HDX & HD Native Systems (Win) 1 05-26-2016 07:59 AM
Graphics Glitches PT HD 11.3.2 steveG Pro Tools HDX & HD Native Systems (Mac) 0 05-25-2016 08:13 PM
