Old 03-07-2012, 01:23 PM
AMZavareei AMZavareei is offline
Default Holy Grail Y Cable Pinouts - HD Legacy Port to Dual Mix Computer Port
Hi all,
Based on this Gearslutz posting, which in turn is based on this DUC posting, I've come up with this pinout diagram for an HD legacy port to dual HD50 Mix port Y cable, also known as a holy grail cable.
I already have a DB60 cable and an HD50 cable I was going to hack apart to make this, but first I was hoping to see if anyone sees any problems with my diagram, or the data I'm basing it on. The biggest cable I've made was about 6 db25 to TRS cables, so this should be a bit of a challenge, I assume. Probably going to splice in, then heatshrink and not actually mess with any of the connectors. One issue I have is the DB60 cable is much thinner than the HD50. Would mismatched gauges cause any capacitance issues, or any other problems?
Thanks for the help!
Old 03-11-2012, 08:09 AM
Howardk Howardk is offline
Default Re: Holy Grail Y Cable Pinouts - HD Legacy Port to Dual Mix Computer Port
I suggest you post this question and chart as a thread on the original postings as well. . .
...for system configuration info see my profile
(Click on member name)
888/24 legacy port ADC Mark Norup Pro Tools TDM Systems (Mac) 8 09-01-2009 04:00 PM
Legacy Port cable OliJ Pro Tools TDM Systems (Mac) 2 01-29-2008 03:09 AM
Help! Legacy port? lifer Pro Tools TDM Systems (Mac) 1 06-11-2007 05:52 AM
G5 Dual 2.7 DVI-Dual port vs DVI-Single port specs Jonathan Starr Pro Tools TDM Systems (Mac) 0 10-19-2005 09:54 PM
88/16 on 192 legacy port.....possible? noize Pro Tools TDM Systems (Mac) 1 01-26-2003 08:27 PM
