Old 11-23-2011, 01:34 AM
syo66 syo66 is offline
Default LE 7.4 and IE 9 compatibility
I know 7.4 is probably no longer the concern of many here however I am still using it (happily enough) and have a question regarding using it with Internet Explorer 9 installed on the same system.
I do know from experience that IE 8 is not compatible with 7.4. But does anyone out there know if it will work ok with IE 9? IE 7 is getting too limiting and I'd like to upgrade if possible.
Thanks for any help on this!
Old 11-23-2011, 08:11 AM
Default Re: LE 7.4 and IE 9 compatibility
Make a drive image and give it a try(the drive image allows you to revert if IE9 is a disaster). Personally, if I had only one computer for everything, I would likely run dual boot, or swap hard drives(SATA drive cages make that really easy on a desktop machine) What OS are you running?
Old 11-24-2011, 06:44 AM
Hey Albee, thanks for the response. I suppose making a drive image wouldn't be a bad idea. I'll give it a try.
I'm running Vista Home Premium. I actually have lots of computers around but as I seldom have more than a 6 or 8 tracks in a session, I've not really had to worry about having a dedicated system or dual boot. Of course it would eliminate having questions like this if I did.
I suppose it's time to get a new system though anyway. Time to take advantage of 64 bit for PT as well as my daily graphics programs. Thanks again.
-syo
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 11:05 AM
V9 Compatibility GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-16-2010 04:51 PM
Mac OSX Compatibility Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-24-2007 09:33 AM
UAD-1 and PT7 Compatibility M15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-08-2005 11:19 PM
PCI-X Compatibility kcurry Pro Tools TDM Systems (Mac) 6 07-14-2003 05:45 AM
