Re: PTMP 8 << lower hardware buffer settings.. hooray!
Yes they need to break it down if it's only for certain interfaces otherwise
I do hope this is fixed with a CS patch. |
We had intended to implement a 64 buffer size for M-Powered devices, however some serious issues were occurring and, after investigation, it's apparent that a lot more work needed to be done to get it working properly.
At this time it's unclear exactly when this may happen. For now, there are no M-Audio devices that will have a 64 buffer. |
i have no problem waiting. |
J |
http://www.gearslutz.com/board/new-p...2626-a-19.html from a profire 2626 thread on gearslutz regarding the 64 buffer for PTMP8: M-audio's Ray T says "Our ETS (Engineering Test Services) department informed me that it was working ok on a Mac but not on a PC. Because of the performance issues the new functionality was removed before release. I'm not sure how/why it made it into the "What's New" PDF. If I am able to dig up any more info I'll let you know. RayT"
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8 |
#16
Waiting anxiously, this will be a big bump for PTMP
#17
So, assuming this hasn't changed yet?
It's funny, in Logic you can get latency with an M-Audio (Digi) device down to 32 samples, using CoreAudio. With Mpowered 8 we still can't get down under 128? Sig |
#18
No, it hasn't changed yet and there's no specific date for implementation since there is quite a bit of work/testing that needs to be done to overcome some problems seen during the last cycle.
#19
Hi there,
I upgraded all my system: OS, bought PT 8, spent 2 days installing everything just because i read on "what's new Pdf" about 64 samples latency with maudio devices (i own a profire) Now i see that nothing has changed and tha latency is 128. Money and time wasted. Thanks a lot. I'm going to use logic for evrything. Lorenzo |
#20
I don't so much mind 128. Probably wouldn't purchase a brand new system and spend thousands of dollars to get down to 64.
Hardware buffer settings. | L-Dogg | Eleven Rack | 5 | 02-17-2013 12:25 PM |
Can't Get To A Lower Buffer Settings | reycantong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-09-2009 07:22 AM |
Hardware buffer size settings? | Eddie D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-03-2005 01:48 PM |
why can't I use lower HW buffer settings? | m nightingale | Digidesign Hardware & Software | 3 | 09-25-2003 10:26 AM |
Aliasing? at lower buffer settings | Chris Cavell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-12-2003 07:45 AM |
