Need help on peripheral cable -- pinouts?
I teach at a university, where (for budgetary reasons) I'm installing a legacy Mix Plus 6.x system on a Mac G4. Unfortunately, the 888 and 882 boxes I bought on eBay came without peripheral cables, and rather than shell out $80 for the Digi 60/50 cable, I obtained the correct jacks and built my own.
Problem: I installed Pro-Tools, but get an error message asking me to turn on my hardware (even though it's already on). I built the cable assuming Pin 1 on the 60-pin end should connect to Pin 1 on the 50-pin end. Was I overly optimistic? Help! Would someone be willing to unplug their 60/50 cable and test a couple of pins to see if it's a straight 1-1 connection, or if it's more complex than that? Thanks much! |
Re: Need help on peripheral cable -- pinouts?
Are you talking about the Peripheral I/O cable ?
If so you may have to spend more than $80 if you get it wrong. You can find them on eBay from time to time for not too much. But they should have come with the I/Os and the cards. The cables are part of the system. |
thats a complex cable and not a pin to pin layout and besides that the cable is a high bandwidth cable and needs to be wired in pairs so how do you figure the internal wire structure ( TX-RX ) matching twisted pairs.
I cant see a tech assuming anything with a cable of this type you are assuming you know the correct cable type, the correct pin-out and pairing, and that you would not potentially blow a LSi chip when you plug in this basically randomly made cable good luck I have one or two laying around for $50 ea.
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Need Peripheral I/O cable for legacy | tommyheadleycox | General Discussion | 3 | 03-13-2013 01:41 PM |
Need Y cable for Session8 XL ou cable pinouts | musicabos | Digidesign Hardware & Software | 0 | 07-29-2005 04:09 PM |
cable for Session8 XL (two 442 I/O) - PINOUTS ! | musicabos | Digidesign Hardware & Software | 0 | 09-05-2004 10:04 PM |
888 I/O peripheral cable length | bderkach | Pro Tools TDM Systems (Mac) | 2 | 12-13-2000 11:47 AM |
5 M Length 888 peripheral Cable | jepking | Tips & Tricks | 0 | 10-21-1999 07:42 PM |
