Old 02-20-2008, 05:11 AM
pablotec pablotec is offline
Default MacBookPro & Magma new test results...
- Macbook Pro + EC34 + 2slot Pericom Chasis:
Mac OS 10.4.11: I tested Magma chasis with following configurations:
A- Digidesign PCI-X HD1, PT7.4cs2: WORKS
B- Digidesign PCI-X HD2, PT7.4cs2: NO WORKS
C- RME MADI HDSP: NO WORKS
D- Adaptec SCSI card: NO WORKS (I tried 4 different models of Adaptec)
E- Sonnet SATA controller: NO WORKS
F- ATTO SCSI 320 NO WORKS
G- VGA ATI9200 PCI NO WORKS
Mac OS 10.5.1 & 10.5.2: I tested Magma chasis with following configurations:
A- Digidesign PCI-X HD1,PT7.4cs2&7.4.1: WORKS
B- Digidesign PCI-X HD2,PT7.4cs2&7.4.1: WORKS
C- RME MADI HDSP: System recognized the card but no the drivers to make it woks (it works in my other 13slot Magma chasis)
D- Adaptec SCSI card: System recognized the card but no the drivers to make it woks (I tried 4 different models of Adaptec)
E- Sonnet SATA controller: System recognized the card but no the drivers to make it woks
F- ATTO SCSI 320 System recognized the card but no the drivers to make it woks
G- VGA ATI9200 PCI System recognized the card but no the drivers to make it woks
Windows XP Proffesional SP2: I tested Magma chasis with following configurations:
A- Digidesign PCI-X HD1: WORKS
B- Digidesign PCI-X HD2: WORKS
C- RME MADI HDSP: WORKS
D- Adaptec SCSI card: WORKS (I tried 4 different models of Adaptec)
E- Sonnet SATA controller: WORKS (with other manufacturer drivers)
F- ATTO SCSI 320 WORKS
G- VGA ATI9200 PCI WORKS
- PowerbookG4 + PCMCIA + 2slot Pericom Chasis:
D- Adaptec SCSI card: WORKS (I try 4 different models of Adaptec)
Note: Protools cards tested> Process & Accel.
Regards
Old 02-20-2008, 10:37 AM
scottgreiner scottgreiner is offline
Default Re: MacBookPro & Magma new test results...
Thanks for posting Pablo. I apreciate you sharing all this info.
I just purchased a Magma 4 slot Pericom chassis for my HD2 Accel (PCIx) to run on a Macbook Pro. As soon as everything arrives and is installed & working, I'll post my findings. Jill from Magma has been really helpful as well
Old 02-22-2008, 10:17 PM
Mauro371 Mauro371 is offline
HI Pablo, all.
Thanks for your detailed post. I have a one slot PCI Pericom Magma chassis and am running into a problem. Even though PT 7.4.1 runs fine with TDM plug-ins, the moment I insert an RTAS plug it starts popping and crackling and eventually it gives me an error I am running out of RTAS CPU power. I first saw this in a 88.2/24 session and thought it was a problem only at that resolution. I have now tried all resolutions and I always end up with the same problem. This is regardless of plug in. Any RTAS plug in will cause it. I have even reproduced this with a new session, one track, one master, different sample rates and bit rates, different plug-ins. I have cleaned directories, caches, erased preferences, etc. Repaired permissions, etc. to no avail.
Has anyone seen this while running 7.4.1 with Leopard (10.5.2) on a MacBook Pro (mine is a 2.16Ghz Core Duo, 3Gb RAM)?
BTW, trying to record at 192kHz is a nightmare, eventually useless with this setup. Gives me 10 TDM voices, but it chokes with 6 channels after a short while.
I have been waiting for a TDM portable setup for quite some time, and was hoping to finally see it working. No RTAS is a deal breaker, though. I too am looking to get a two or four slot PCI chassis, but am curious to see if others are also getting errors with RTAS plug-ins.
Old 02-23-2008, 06:21 AM
Oliver M Oliver M is offline
Don't use 10.5.2! Install 10.5.1.
Oliver
Old 02-23-2008, 10:48 AM
Hi Oliver,
Thanks for your suggestion. Are you running 10.5.1 and not having problems with RTAS with a MacBook Pro and a Magma chassis? If so, I will downgrade to 10.5.1 or create a new partition for it.
Old 02-25-2008, 07:43 PM
Apparently, some that have the supported systems (10.5.1 on MacPro 8 cores) are also having problems with RTAS plugs. See the thread:
"Leopard/PT/7.4.1 issues"
2. Quite regularly now, but randomly, even is very small sessions, whilst playing or recording, the audio will go into a weird loop of itself, playing one section (randomly) of about 5 secs of audio over and over for 3 to 4 times, playback will stop, and I get the warning window stating 'you are running out of CPU power; Remove some RTAS or increase CPU usage limit in the PB engine dialog. (-9128)'..I open the 'system usage' window, and I'm barely even registering any CPU load...I only have one or two RTAS plugs open...and yes, they are upgraded and compatible with 10.5.1/PT7.4.1. CPU usage has been increased to max in PB Engine Dialog, I am still getting the same errors/warnings. Any ideas anyone??
Thanks in advance.
This is the same error I am getting with RTAS plug ins. Anyone else having problems with Leopard, 7.4.1, and RTAS? With/without Magma chassis?
Old 03-02-2008, 07:14 AM
Pablo,
Have you run into any problems running RTAS plug-ins? Also, can you please post what version of the MacBook Pro were you working with when you did the tests?
Anybody else running into trouble with RTAS plug-ins in a "portable" TDM setup with the pericom Magma chassis?
Old 03-03-2008, 06:20 AM
jacko's Avatar
jacko jacko is offline
how's the RTAS thing?
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 03-03-2008, 04:22 PM
Fritz Fritz is offline
today I tested:
MBP dual core 2.4GHz w/2G ram running 10.4.11, PT 7.4.cs2.
ioGear FW/USB powered hub. Ext kb & tball.
e34 Magma 2 slot Pericom. 1 Core, 1 Process, PCI.
w/20 incidence of Waves TDM Ren channel. All ran well with no problems. Core card Wave slots almost full.
Only thing I notice is as soon as the e34 is plugged in, the Menu bar clock goes away and Spotlight flashes randomly on/off on the Menu bar.
Spotlight activation key combo disabled and replaced with Quicksilver, which I prefer.
No other ills so far.
Firewire 400 drives only.
I will probably update to Leopard as per the info I have from Magma.
Next I'll try an OMF import/export and video out FW with a Canopus.
"Do not fear mistakes. There are none."
Miles Davis
Old 03-03-2008, 08:28 PM
jacko's Avatar
could you please check RTAS plugins instead of TDM, ideally with different buffer settings
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
The Test Results are In!!! dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-03-2008 10:05 PM
Protools 7.4 on MacBookPro, official supported by Magma!!! pablotec Pro Tools TDM Systems (Mac) 11 01-25-2008 01:18 PM
MacBookPro - Magma 4 Slot ExpressCard Chassis - PT Andi R Pro Tools TDM Systems (Mac) 3 12-26-2007 07:49 AM
Macbookpro running win XP results acappellajosh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 04-29-2006 08:42 PM
Powerbook 800/Magma/HD2 test results CraigLearmont Pro Tools TDM Systems (Mac) 0 02-10-2003 09:48 AM
