Hey Friends,
I know this subject has been discussed before, but nothing lists exact steps to fix the issue, so I'm hoping one of you guru's can steer me in the right direction. I'm running PT7 on OSX Tiger, and just purchased the UAD-1 card, but can't seem to get the latency introduced by the card under control. I got it from Sweetwater, but thier support team keeps telling me it's my PT setup, not the card, which I don't 100% believe. What is the best way to compensate for the delay introduced? Do I use the DelayComp included? Is there a "UAD-1 For Dummies" website or posting somewhere that details how to do this? Any help is appreciated. Thanks in advance!! Jason |
There are a few ways to do this,
you could check how much a track is delayed in the small window under the fader in the mix window (apple + click in mac) and them shift the audio on that track earlier by that amount. Or you could use the UAD TrackAdv plugin on every track except on the track where you are using an UAD plug-in. Or you could create a Aux track and put a TrackADV plug on that and buss every channel without a UAD plug to that Aux fader. So as you see there are a few ways of getting this to work. Just a notion, if you are working to picture the there is just the first option of shift audio, othervise you are in trouble. Mats B |
Cool. I'll go home tonight and give this a try. Thanks man!
Jason PS - for anyone who may search this topic in the future, I found this article as well. http://www.uaudio.com/webzine/2004/february/index5.html It is regarding Digital Performer, but the concept translates to Pro Tools. |
Hey Mats,
I'm not using a UAD card, but I am using plugins that cause a delay on the track. Any idea why my delay (cmd+click) is ALWAYS at 0? Tom. |
![]() Quote:
Quad 2.5 G5, 4.5G RAM |
Does SansAmp report 0 for you (or anyone)? I can hear the phase difference so it must be delayed. I'll get a list going.
If it sounds like phasing, rather than a delay, it's probably a very small delay. You can measure it with ProTools easily, just record a single click on an audio track, then apply the plugin and record the result to another audio track. Then zoom in close on both tracks, and you can measure the delay in samples.
![]() Quote:
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
After re-reading this, I realized you're using the VST-RTAS adapter. This will always add latency - how much depends on the buffer setting in the wrapper.
![]() Quote:
Don't know about the UAD
can't adjust any plugins... | alexruimy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-03-2014 11:42 PM |
How to adjust record latency with ProFire 610? | Avi Bortnick | Pro Tools M-Powered (Mac) | 15 | 02-10-2010 11:55 AM |
How to adjust record latency with ProFire 610? | Avi Bortnick | Pro Tools M-Powered (Win) | 0 | 02-09-2010 05:14 PM |
How do i adjust gain on 003+ | Maddawg383 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 25 | 03-09-2009 08:24 AM |
Fine adjust fader in edit window caput! command+adjust | crizdee | Pro Tools TDM Systems (Mac) | 2 | 12-09-2008 04:55 PM |
