In the same boat here with a Dual 2.7 PPC and Accel 2.
It's such a lot of money to go up to PCIe and all that we are getting is increased VI performance. (yeah I know that means a great deal to some) Like others on this list I am not complaining as my rig has served me well and those Accel cards are the best purchase I ever made. It's more about a workflow I think. I don't need to have a bunch of VI's running all the time. I do rely on them heavily but I just print them and keep the raw track deactivated. It's really no hardship. The trick is to commit to a part and move on. If you have to come back and change it you can. Some VI's don't tax the CPU much. RMX and Addictive Drums are great and I just leave that running all the time.(same with Superior 2) Omnisphere is ok if you only have 1 and maybe use 4 channels. The other day I discovered that I had forgotten to print my Omnisphere tracks and the rig was chugging along just fine with RMX, Omnisphere and a bunch of API RTAS plugs and ....yes.........even a Maserati Guit Plug. So I agree that it's not the end of the road for everyone who is running a G5. It seems to really affect those who want to keep a bunch of VI's running in one session. If you can work around that then there's plenty of life left in the old girl. Damn I just got used to thinking that my machine was a new shiny "king of the hill" powerful beast. Then those dirty rotten Intel Machines came and kicked sand in her face. |
![]() Quote:
I know it's not the end of the road for our G5, just still trying to make a decision if "Tiger PT 7.4" is the "End of the road" for the G5's life of Upgrades.
David - MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3 - HDX II Sonnet xMacPro Server - 16x16 HD i/o x 6 - PT 2018.10 - OS X 10.14.4 - ProTools Dock / PT Control |
Yeah Leopard and PT8 using one processor.
One thing that really helps is adjusting the playback buffer as needed. That was a tip I picked up from a Scott Church video (thanks Scott). I used to think that the buffer was just "set and forget" but that's not the case. When I am recording midi I will have it at 256 but if I'm just on playback and finished with my midi parts I will change that buffer much higher. It makes a hugh difference to RTAS performance. Just watch the meter drop! The down side is an increase in delay comp and I sometimes forget to change the buffer when I decide to record some midi. That messed with me for a while. Worth having a look at. Things like Ampeg SVX I will always print. Also ....usually............any of the Maserati plugs. But also don't forget your Audiosuite plugs. I am one of those who rarely use them. Not the case anymore. When I get my bass where I want it with SVX I would normally run the track down and lay it but now it's just a matter of selecting the track and processing with AS. Same with Maserati. I know people have been doing that for years but I......er.....never thought of it. It's made a big difference to my workflow. |
![]() Quote:
Chris
![]() Quote:
![]() I asked around but Digi wouldn't confirm and wouldn't say in threads on this site that there's a problem with older G5's ![]() Bottom line is if you have a older G5 dual 2.0 you would need to upgrade it would cost $3500 for computer and around $3000 for exchange ![]() Digidesign and Microsoft should get together because the designers/developers are one of the same.... ![]() |
![]() Quote:
Bottom line is my G5 dual 2.0 performed really nice with PT 7.4. With PT 8 it's not the same. At least DIGI guys could let us know that this problems could occur on older machines before we spend money on it. It's simple like taht: Minimun setup: G5 RECOMMENDED SETUP: Mac Pro. Simple.
http://www.ricardomosca.com Intel Mac Pro 12 core 3.33 GHz, 48GB RAM, OSX 10.13.6, PT HDX, PT 2020.9.1, SSL 4040G+, tons of outboard ![]() Mac Book Pro 2019 2.4Ghz i5, 16GB RAM, OSX 10.14.6, PT Vanilla 2020.9.1 |
![]() Quote:
If you're going to use a particular VI, shouldn't you look at the system requirements for it, to determine how well it would work on your system? For instance, Omnisphere: Quote:
And BFD2 - look at the minimum vs. recommended on this page: http://www.fxpansion.com/index.php?page=53&tab=149 Quote:
I understand where you're coming from, but I wanted to give you our point of view - if you're going to run processor intensive VI's, you should be following the VI manufacturers recommendations. Does that make sense as to why we aren't going around posting 'warnings'? We like to think that customers understand enough about their systems to know they need to check system requirements for any 3rd party plug-ins if they're going to use them in Pro Tools. Are we wrong in that assumption? |
DigiTech:
Under PT7, I have found that when using Ampeg SVX, I get a lot of pops and clicks, especially once my RTAS usage meter gets to about halfway up. Based on this thread, I just reduced my processor setting down to use only one processor (on a dual 2.0 G5), and the clicks pretty much stopped, but of course the RTAS meter went way up. Am I better off using one processor and running as much as I can until get a warning error pop up, or using two and keeping the usage meter down low. Any recommendations? Right now I am pushing the limits, mixing ITB about 90 voices at 88.2 k, so I need all the power I can get, without pops. :)
www.clifnorrell.com |
![]() Quote:
I liked that 9600 system. I got a lot of work done. I'm resigned to the fact that my system is reaching the end of its cycle and I'm once again at the point where I'm going to hang on for a little while and see what both Apple and Digidesign do in regard to hardware. In the meantime I'm working everyday with a ridiculously inhuman schedule and I seem to be getting everything done and delivering. Bottom line is you can't blame Digi for progress. I'm glad they are moving forward. What I will complain about is the cross grade price to PCIe. That stopped a lot of us changing. I'd go as far as to say the pricing policy was opportunistic. Harsh word but there you have it. |
![]() Quote:
I'm not using any VI's. I'm using RTAS plugins, normal ones. Why my G5 can handle all this plugins (the same ones) much better in Logic than in PT8? It's worst then PT7.4. That's the only complain I do have. Is my G5 outdated? Yes, I agree, BUT, the same computer, with the same OS (Leopard), with the same plugins, works just fine on Logic (I hate logic BTW) and NOT on PT8. That's it. We're just wondering what happened...
Problems when using all 4 cores vs. 3 cores | hopelessennui | macOS | 1 | 02-03-2012 07:54 AM |
Mac Octo 2.26: Almost no difference between 2 Cores and 8 Cores | Hive Guy | macOS | 8 | 05-11-2011 12:05 AM |
better performance from 7 cores than 15 cores? | stevesound | macOS | 4 | 03-30-2011 12:48 PM |
Can all Mac Pro 4-cores run Tiger? | johnnyv | Pro Tools TDM Systems (Mac) | 5 | 06-07-2008 04:06 PM |
anyone running tiger smoothly on new 8 cores? | alw4416 | Pro Tools TDM Systems (Mac) | 11 | 04-19-2008 08:26 PM |
