#81
![]() Quote:
So please, if you don't mind, let me continue with the line of questioning and if you require further assistance please answer the questions I've asked of you. |
#82
I have answered every question and still no response from Digidesign and I'm not the only one with this problem
#83
Hi all,
I have a new machine. I've done all the optimising as recommended. I have a few TDM plugs on, then I add Amplitube 2 (latest version). I get the stutter, repeat and stop as reported by others. I reduced from 8 to 7 processors and managed to run the session for a bit longer. In terms of length - the first time (8 processors), I hit 'play' and got the problem. On 7 proc... I played for a good 30 seconds. I'm not overly hacked off, as I expect some teething troubles. If I get this kind of problem, I generally put a plug-in on a track and then, when I'm happy with it, I record it to another track as an audio file. Luddite, but it works as a get-by. Here's my general question: is reducing to 7 sufficient? i.e. - will reducing to 6 be better? 5? 4? You get the idea: is there a general optimum? I have 6GB RAM, but have more ordered that will take it to 22GB. Will that make a difference? (I'm never sure about the RAM and/or CPU difference in terms of what the machine eats). I'm just looking for a wee bit of advice, and I certainly won't be shouting back "You said this would help and it didn't!" or similar. If there are recommendation - I'll give them a try and post my findings, as quite often, when I'm searching posts, that just the sort of info that can really help. I've never found a load of posts complaining about how much cash has been spent to be actually helpful! Anyhoo - If Mr. Digi is reading this - please let me know your thoughts. I'll try them out next week (on location in about two hours for the rest of the week). Ta much. Specs: dual quad 2.8GHz MacPro. Separate partition for audio samples. Separate internal drive for PT sessions. 6GB RAM. The machine is not used for anything other than audio. OSX 10.5.5, PT8.
Cheers, tsugi |
#84
![]() Quote:
Ok, I'm going to need you to post your installed plug-in version list and let me know the following: 1. Which drive you're recording/playing back from 2. If you have video in your session 3. If you have any other peripherals connected to your computer and, if so, what are they. 4. Have you tried reducing the number of processors by 1 and, if so, did anything change. 5. You said earlier that you had a session that was working - what's different in that one vs. ones that aren't working? 6. Did you do a clean install of Leopard or did you upgrade from Tiger? 7. Did you do a clean install of Pro Tools 8 or did you have a previous version installed and just upgrade it? |
#85
![]() Quote:
Typically going down to 7 should work fine, however it really depends on how many plug-ins you have in the session that aren't fully RTAS optimized. The more of those you have, the more you'll need to lower the number of processors. Keep in mind - by lowering the number of processors you're not really 'losing' anything. Processors dedicated to RTAS can only run real-time optimized plug-ins. If you have plug-ins like Amplitube in your session, you need to give them processor time separate from RTAS processes - so those processors still get used, just for different things. I doubt you should need more than 6GB RAM. Also, keep in mind that we have seen issues on systems that were upgraded from Tiger, rather than having a clean install of Leopard. If you install Pro Tools 8 over a previous version that can cause problems as well - doing a clean install of both versions and then reinstall just Pro Tools 8 will likely clear things up. It is imperative that you only have compatible plug-ins installed. Having any incompatible ones installed, even if they're not used in the session, can cause all kinds of issues. Pro Tools Plug-In Compatibility Grid |
#86
Below is all my post on this issue if you can't comprehend what I'm running is there someone that can read
![]() ![]() 1. Which drive you're recording/playing back from READ BELOW 2. If you have video in your session NO 3. If you have any other peripherals connected to your computer and, if so, what are they. NO 4. Have you tried reducing the number of processors by 1 and, if so, did anything change. NO 5. You said earlier that you had a session that was working - what's different in that one vs. ones that aren't working? I LOADED A SMALL SESSION WITH 4 TRACKS TRIED RUN ONE TRACK WITH RTAS ORGAN AND THERE"S A PROBLEM 6. Did you do a clean install of Leopard or did you upgrade from Tiger?READ BELOW FROM MANY PRE POST 7. Did you do a clean install of Pro Tools 8 or did you have a previous version installed and just upgrade it? READ BELOW COMPREHEND!!! Quote:
#87
Why didn't Digi say older G5 dual 2.0 are not valid using PT8 ?????????
#88
![]() Quote:
I have a G5 2gig dual and i'm not getting the real big problem you have with running just 4 tracks and one instance of the DB-33 organ. it has to be something specific to your setup! as i can get literally dozens of DB-33 in a session on a G5. The VI problem really is down to each specific plugin Vendor and whether they have or can, code their RTAS plugins to make use of multi processor CPU's. many of these Vendors just aren't prepared to go back and re-code their plugs. they just want to rush the next product to the market to get $$$ coming in. So unless Digi are holding something back from the third party vendors, and i really doubt that would or could happen!! then Digi-Air have proved it is possible to get very efficient VI's working as RTAS. Saying all that! we all know that RTAS isn't perfect or as good as it could be. we are all still boggled why we could get 40-50 EXS24 samplers in a Logic session on a G4 ![]() Chris
#89
![]() Quote:
You missed this one: Quote:
You also say: Quote:
Lastly, can I ask why you feel it necessary to insult me, even though I'm just asking questions meant to clarify exactly what you're doing? |
#90
Whoa 'theblasters' -- no need to blast DigiTechSupport - calm down... [sorry for the bad pun]
He/she is only requesting follow-up to your answers. Do you think you are being more productive by acting rude? Quote:
Kurt Bullock PT 7.4 HD2Accel Digi ProControl G5 Dual 2.7 3.5gig RAM OS10.4.8 www.zeropointrecording.com |
Strike RTAS - Memory Issues | FierceBrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-26-2008 10:13 AM |
Please help on memory usage w/RTAS plug-ins | el biciclista | Pro Tools TDM Systems (Mac) | 6 | 12-11-2006 04:27 PM |
Kontakt RTAS PC Digi002 Physical Memory Low ,-9128 | skizzee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-04-2004 01:35 PM |
RTAS and REWIRE performance?? free memory needed?? | dk01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-23-2003 01:09 PM |
RTAS and memory | MacPhearson | General Discussion | 1 | 02-09-2001 09:31 PM |
