Old 12-28-2015, 01:03 AM
mtung mtung is offline
Default External Startup disk work with differnt machines?
If I make a clean install of Mac OSX and protools, will it startup on different machines?
Old 12-28-2015, 01:07 AM
Dan Smith's Avatar
Dan Smith Dan Smith is offline
Default Re: External Startup disk work with differnt machines?
Yes. I've used the same boot drive to startup Mac Pros, iMacs, and MacBook Pros. No problem. Haven't done so with El Capita. But I highly doubt that it has changed.
Old 12-28-2015, 06:45 AM
Not necessarily. It depends on the OS X levels supported on each of the Macs.
Old 12-28-2015, 09:39 AM
Dan Smith's Avatar
That's true, very good point. So if you have a new machine that doesn't support any OS before 10.10 then when you try to boot Mavericks on that machine it won't work.
Old 12-28-2015, 09:48 AM
Issues also go the other way with old systems/EFI that will not boot newer versions of OS X even on Intel Macs. And then what disk is it on? FireWire 400? 800? USB 2? 3? 3.1? Thunderbolt? Chances I would want to boot off a USB 2 or FW 400 drive for maximum compatibility across systems is uh zero. So like always questions like this are really only useful in their details, and online resources already explain what OS X versions different Macs can run.
Old 12-28-2015, 11:20 AM
Thanks for all this info. The machines are of the same age, but different processor cores and speeds, so I'm optimistic that there wont be any trouble.
Startup disk zzstation Post - Surround - Video 3 02-10-2012 03:18 PM
work from a bootable external disk... montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 02-01-2011 07:25 PM
OT....Deleiting a Startup Disk. Possible? G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-02-2004 11:17 PM
Do "supported" machines work right with ASIO? apetrocelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-29-2004 10:46 AM
External Startup Disk mly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-08-2003 05:13 PM
