Re: Audio Dropouts
Will do..
BTW Mykhal, the digilink that must be short is only between 2 HD IOs, not between the card and the IO. They have 50' digilink from the card. |
Re: Audio Dropouts
thanks for the correction
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Re: Audio Dropouts
Problem Solved.
Seems it was Time Machine causing the glitch when it would start up and when it would finish up. Never happened with my old G5 and TDM system. Must be a resource conflict with OSX and the HDX system. Seems like Apple wants its built in apps to run smooth at the expense of audio processes. |
Re: Audio Dropouts
"Disable Time Machine It is NOT recommended to use Time Machine on the same hard drive that you're recording to in Pro Tools. This can result in DAE Error -9131 even if you have Time Machine disabled. Even if you're using Time Machine to backup your system drive, it is still recommended to disable it when using Pro Tools as it still uses system resources to back up the data. Click on the 'Time Machine' preference. Move the slider to the Off position."
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Re: Audio Dropouts
Thanks Park for the link.I backup to a remote drive with no pro tools files or sessions. Timemachine was never a problem in the past but seems to now be with HDX.
I know all the things they want shut down like Airport, Bluetooth etc. They never got in the way and only Time Machine, even going to a Time capsule and no system or audio drives, seems to steal the CPU for very brief periods of time while starting and stopping. Just a heads up to anyone who migrated from HD to HDX and suddenly gets these dropouts. Thanks for all your help. |
#16
Re: Audio Dropouts
I'm experiencing random dropouts. Pro Tools 11.2.2, OSX 10.9.5, on a brand-new Mac Pro. (It did not happen on the Mac Pro that's only a few weeks older, and which is going back to Apple for an unrelated hardware issue.) It happens on both playback and bounce. The dropouts last about a second each, and are not repeatable. I tried recording some audio from a mic through the Mbox 3 and the audio records correctly, but I can hear the dropouts through my cans as I record.
I've also tried every HW buffer size, and already have "ignore errors" unchecked, but tried it both ways. It is not the disk drive. I copied a project to the internal SSD (wicked fast) and it made no difference. As I composed this I thought maybe it was the Time Machine backup. But, no. Turning off Time Machine made no difference. Neither did turning off Bluetooth and Backblaze (neither of which have ever caused issues in the past, even on my one-lung laptop). I have also reinstalled Pro Tools from the download DMG. Editing this way is severely inconvenient. But delivery is impossible, so I'm virtually dead in the water.
-- Craig Good Teller of stories, some of them true. Last edited by clgood; 11-30-2014 at 02:42 PM. |
#17
Re: Audio Dropouts
Do you have PT10 co-installed? If so try opening it up in 10 and see if the problem persists.
#18
Re: Audio Dropouts
Thanks.
-- Craig Good Teller of stories, some of them true. |
#19
Re: Audio Dropouts
Well, I'm telling my story in case someone else in the future has mysterious dropouts after setting up a brand-new computer, because the fact that it is brand-new really matters to the story. Get ready to laugh. Go ahead. I have it coming. I just happened to pop open the iZotope Alloy 2 plugin on one of my tracks. It asked for authorization. Because brand-new computer. Guess what iZotope trial mode does. Yup. Random silences. So, future tearers-out-of-too-little-hair, check those plugins.
#20
Re: Audio Dropouts
Oh man. Well, you tracked it down. We've all had moments like these.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Audio dropouts at 48k | youngas75 | Pro Tools 11 | 2 | 11-06-2013 08:25 AM |
Audio Dropouts in PT 8 | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-10-2010 06:12 AM |
audio dropouts | 2000mpc | General Discussion | 1 | 07-09-2010 01:18 PM |
Audio Dropouts on Playback | barstool719 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-01-2008 11:59 PM |
Audio dropouts help | YUL | Digidesign Hardware & Software | 0 | 11-13-2001 08:06 AM |
