Old 01-19-2018, 03:13 AM
Kaskinho Kaskinho is offline
Default 30 days free trial protools 11.3
Hi, i cant import files and get everytime this window:
Audio coundnt be imported because: Assertion in Volumes/Development/148093/Protools/NewFileLibs/Cfd/MacBuild/../<macoS/Cfd_ImportAudioDialogMacOS.mm, line 559
Does anzone have a tip? does it maybe have to do with the trial, and if i rent it for a month or buz the license it will work?
Many thanks
Old 01-19-2018, 04:59 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: 30 days free trial protools 11.3
You should be running Pro Tools 12 on Sierra. I'm not sure that the 11.x versions will run properly on that OS.
You can check the compatibility chart here for version 11.
Although not as full featured, you may want to download and try Pro Tools First before you invest any money on the latest version. Pro Tools First is free and is based on the 12.x version of the software. If PTF runs on your system, then you would be fine upgrading to the standard edition of Pro Tools.
I would also remove version 11 from your system before installing PTF.
Will
System Details
Old 01-19-2018, 08:38 AM
Southsidemusic's Avatar
Hello and Welcome to the Community,
You can try holding the N key down when bootng PT11 and choose the interface you have or built in audio if thats what you have.
And trash preferences and databases aswell to rid old stuff from the setup.
Explained here :
https://www.sweetwater.com/sweetcare...s-preferences/
Let us know what happens
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Protools free trial. Trouble activating deslog Getting Started 21 07-21-2017 11:01 PM
Pro tools 11 (30 days trial version) [email protected] Pro Tools 11 6 12-14-2015 07:26 AM
ProTools 11 trial extension. In the middle of a project, trial expiring tonight bimbom macOS 2 02-22-2015 12:36 PM
PT 11 on 3,1 Mac with RME 800 has stopped outputting audio-Help 4 days left on trial b mcgibney Pro Tools 11 1 07-21-2013 02:11 AM
Out of free uldate for only 5 days! eledu macOS 9 04-08-2013 10:06 AM
