routing audio to a track
guys,
pro tools le 5.3.1 i cannot find the mic/lines 1 & 2 to the analog3-8 inputs when i click: file > new track it reflects no input in the pop up menu and no outputs what the hell is going here please help me out on this Thanks Soca |
Re: routing audio to a track
Assign the input after creating a track. It's covered in the manual.
You're looking in the wrong place.
In the Mix window- You need to click on the track's i/o assignment. (At the top of the fader strip, 4 rows up from 'auto read' or in the Edit window, enable Display> Edit Window shows> I/O view. When you create a new track it should just default to A 1/2 which is Analog 1 & 2... those are distinct and separate from the other 3 thru 8 inputs. Hope this helps |
thanks guys
im going to take your advice .i'll post back in few to let you know the outcome |
results
in the mix window i click on i/o assig. on the fader four rows up from auto read it reflects the following in 1(when i click this the pop up show this) no input interface ---in 1 to in 16 bus--- verb send to bus 16 i still can get the default (analog inputs and the mic/line inputs) HELP |
What you described is a normal assignment menu.
It should say: Interface> Mic/Line 1 Mono. That would be a normal menu on a mono track. Just click one of the input choices, in this case, the Mic/Line 1. You should then see that choice on the 'bar' that represents the I/O assignment. If you have created a stereo track then the option should show up in stereo pairs, as Mic/Line 1-2... Analog 3-4, etc. The No Input applies if you're going to be using that track as an edit track or other uses. Don't worry about that now. So if that's NOT what you see, you need to reset your I/O to default settings. Here's how: Setups> I/O Setup> Input Tab> Click Default... Click on the Output tab and do the same thing. Click OK to close the menu. Now go back to your track I/O assignments and see if it looks normal. If nothing changed yet, then Save and Close the program and re-open the program. Let us know if it does not make things look right, as in stereo pairs for a stereo track, or single mono channels for mono tracks- there is one more step we MAY need to take, but I'll stop here for now. |
STONE
Thanks for your help i'll try that now |
it works, thanks guys for you help. i know down the road i will need more assistance from you because im a green when it come to this .this forum is the best on line support ever .
by the way what do you think about the waves gold bundle? is it that good soca007 |
I only have the Waves that were included with the 001 Factory, but every one is excellent. I imagine the rest of their stuff is also very good. Some are quite CPU intensive, but the quality is right there.
Glad to hear you're rollin'! [img]images/icons/smile.gif[/img] |
I have the Waves NPP, wich shares some components with the gold-bundle. It sure is pricy, but its well worth it. I suggest that you download them. (they offer a free 14 days fully functional demo)
Goto www.waves.com and click on the download-tab.
What's that? - That's the machine that goes "pling". Bastiaan |
monitor routing m-audio fast track ultra | shadowdaze | FireWire & USB Audio Interfaces (Win) | 1 | 03-12-2014 09:07 AM |
Aux track routing to audio track not working | lawdaproducer | Pro Tools M-Powered (Win) | 1 | 12-29-2009 12:56 PM |
Routing vst instruments into audio track in pro tools 8 | ostrange | MIDI | 1 | 05-19-2009 05:24 PM |
Routing Reason to a PT audio track | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-14-2004 06:11 PM |
