Application Manager
Does Application Manager work for ANYONE? Why do they keep updating it, if they won't fix it? The troubleshooting guide mentions:
"Not responding ("Authenticating" or "Initializing") Unable to connect to the Avid servers" but then gives NO advice on how to fix those issues. Somebody is asleep at the code wheel.... |
Re: Application Manager
I uninstall it immediately. It's useless.
using PT 2023.9, 24' iMac M1 16GB RAM, Ventura 13.6.1, Apollo Twin interface |
It’s awfully poor quality code that might work for a while OK and then will have problems. Should be an automatic uninstall. Kind of what I expect you might get when an outsourcing/third party development company sells a struggling software company on outsourcing development to some low-cost overseas team....
I also uninstall it immediately, making sure to uncheck the uninstaller itself.
I use it infrequently to check if any plug-ins need updating, but have it stopped from starting automatically when Windows starts - thanks CCleaner.
never experienced a prob with AM at this stage as it seems to function as expected... is this an issues with particular versions or setups?
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
I also faced the same issue. I also uninstalled it as it was not working properly.
Application Manager... | Darren Harker | Licensing & Accounts | 1 | 09-07-2018 12:16 PM |
Application Manager | jchan | Pro Tools 12 | 3 | 11-07-2017 09:13 AM |
12.8.1 Not in Application Manager | taylor4814 | Pro Tools 12 | 6 | 08-28-2017 09:54 AM |
Can Not Log In To Application Manager | MicESanzMusic | Pro Tools | Intro Discussion | 5 | 07-02-2017 07:55 AM |
