Do I need multiple reverb Aux returns for this?
If i have 5 mono tracks that I want to send to a reverb but have the the reverb in different locations for each track, do i need multiple mono reverbs?
I first assumed I could have my mono tracks sending to a stereo reverb and they would only play back on the stereo reverb based on where the mono send was panned. (Kind of like the stereo return hosting a bunch of different mono signals) But now I'm realizing that regardless of where the mono send is panned, the reverb still plays back hard left and hard right where the return is panned. The point of all this was so I could have a bunch of mono signals using the same reverb but going to a different mono location, i figured if the return was stereo then I could just pick wherever in the stereo spectrum that I wanted to, but it just comes back as full hard left/right stereo. SO, in this case do i need to make multiple mono reverb sends for each instrument and pan each aux return to where I want each instruments reverb? Theres no way to have one stereo reverb hosting multiple tracks reverbing to a different location? |
Re: Do I need multiple reverb Aux returns for this?
You are essentially stereo-izing your tracks by adding a stereo reverb.
Think of it like having 2 guitars/amps in a room. You can move them from both in the middle to one on left side of the room and the other on the right, and while placement influences the reflections, the 'reverb' of both will still basically fill the room (it doesn't strictly follow the placement of each amp). If you want the reverb to follow the stereo placement of the track then you could try one of the following:
• linkedin •
Rc24/48, QL Spaces.
Looks like the easiest way for to me to do things will just be to create a few different mono returns pointing to different locations. But then ill need a different reverb for each of my tracks assuming I want to keep the reverb close to its original dry signal and not clashing with another tracks reverb.. that kinda sucks. |
Why don't you just try the regular thing with a aux and sends, but with a multiple mono version of the reverb? It should at least give the impression of the reverb return following send pan. It most certainly will behave differently.
• linkedin •
I just tried this. A multiple mono Dverb on a aux track, a stereo send on a track that goes to the aux, and the pan on the send decides where in the stereo field the reverb is placed. Works perfect. Regular stereo Dverb on the aux, no worky. In case anyone's interested.
Reverb On Multiple Instruments | mrgroovy | Tips & Tricks | 18 | 07-15-2013 09:06 AM |
not using any fx-returns | Rockpolice | VENUE Live Sound Systems | 1 | 09-13-2007 11:24 AM |
?-aux returns for reverb-help? | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-21-2005 07:08 PM |
HDL Returns | Shan | Pro Tools TDM Systems (Mac) | 0 | 04-10-2004 11:20 PM |
Can hardware sends & returns be used on multiple channels? | novstar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-11-2001 05:27 PM |
