Old 12-07-2012, 07:42 PM
Wave D Wave D is offline
Default Not recognizing optical inputs 17-24(Profire 2626). Help needed.
Hey guys,
I wanted to record 24 inputs for a quick demo this weekend w/ my Profire 2626 so I borrowed two of my friends Motu 8pre's to run into my Profire 2626 via ADAT ports A and B to get myself there.
My connections are as followed
Profire ADAT A out ---> MOTU(1) ADAT 1-8 in(clock synced to external no issues)
MOTU(1) ADAT 1-8 out ---> Profire ADAT A in
Profire ADAT B out ---> MOTU(2) ADAT 1-8 in(clock synced to external no issues)
MOTU(2) ADAT 1-8 out ---> Profire ADAT B in
All of the units are synced and I can see any input lighting up and I can monitor any one of them in on the Profire 2626 dsp mixer
In pro tools the default inputs were 16 so I created 8 more to give me 24 and I had the set up as this.
Analog 1-8
Optical 9-24
The issue is that I'm seeing no signal in pro tools from the optical inputs 17-24, which would be the 2nd Motu 8pre in the chain.
Now I can see levels on the Motu and I can even monitor and hear the signal on the internal dsp mixer..but nothing comes into pro tools.
Any help or suggestions is appreciated.
Old 12-08-2012, 12:59 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Not recognizing optical inputs 17-24(Profire 2626). Help needed.
Just a few things to check, but I'm not sure how the profile works in relation to the hardware setup, but check...
Setup/hardware...
make sure the various inputs 1-8 / 9-16 / 17-24 are all assigned to the desired analogue or adat inputs.
Check if anything here needs to be selected as digital adat for the 17 - 24 inputs to work.
Setup/ I/O all inputs have been created and assigned to the right inputs on the hardware.
The boxes are ticked for the inputs to be active.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-20-2012, 01:06 PM
The Dougfather The Dougfather is offline
Pro Tools is a PIA for this and it's a real gotcha.
Go in to the i/o window and under the input and output tabs press 'Default'.
VOILA!
If you regularly change interfaces then you need to almost do this as a matter of course, saving some custom i/o setups is always a good thing too!
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Profire 2626 Inputs obiwan177 Tips & Tricks 7 08-03-2010 10:03 PM
Only 4 inputs for profire 2626? barters81 Pro Tools M-Powered (Mac) 1 05-01-2010 05:07 PM
Profire 2626 analog INputs 3-8 Don't show up norton Pro Tools M-Powered (Mac) 3 11-06-2009 10:38 PM
M-powered not recognizing my Profire 2626 mburton21 Pro Tools M-Powered (Win) 8 06-16-2009 10:39 PM
advice needed: PPC G5 with 2x Profire 2626?? martthie_08 Pro Tools M-Powered (Mac) 6 12-05-2008 03:53 AM
