OSX 10.7.3 and Eleven Rack!
Update: It looks like the repair permission procedure worked! Thanks to Deny for the suggestion!
Re: Beware of OSX 10.73 and Eleven Rack!
Revised test procedure that worked for OSX 10.7.3 and the Eleven Rack
a) Wiped the HD clean, and installed a virgin 10.7.2 b) Installed the 10.7.3 Combo Update c) Repaired Permissions d) Installed Pro Tools 10_73451 e) Installed Eleven Rack Drivers v1.05_73510 f) Installed Eleven Rack Expansion Pack _73715 g) Repaired permissions and rebooted System: iMac 27" Late 2009 Quad Core 2.66Mhz with 4GB 1067Mhz DDR3 Firmware: Rev 2.0.1 Build 0.1.5.7 Last edited by sorcerer27; 02-08-2012 at 07:40 AM. Reason: Working |
Re: Beware of OSX 10.7.3 and Eleven Rack!
Please try the following procedure also:
1. Open "Disk Utility" 2. Select "Macintosh HD" 3. Click on "Repair Permissions" 4. Reboot 5. Re-test 11R connectivity And please let us know if it works. |
Repairing permissions is not going to fix this issue!
Update: It did fix the issue! Thanks Deny for the suggestion! |
Have you tried?
I personally think that will be a waste of time! Care to wager on it? :) Maybe I'll do it tomorrow just to prove my point. I've already re-loaded my system twice today to test things.
well g@!# da@#$ it...I'm running 10.7.3 and I was going freaking crazy as to why my 11R wasn't recording on pro tool 10 anymore...un installed and re-installed, 11R wouldn't show up in PT10, uninstalled it and re installed it again now I get fockin error message stating it's not compatible...
I rest my case! :) Mirage2992, care to run repair permissions on your system and tell us the results?
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Some experimental tracks using Eleven rack and Eleven RTAS | kittybite | Eleven Rack | 4 | 06-18-2013 12:18 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Beware Rack 002 users - Digi won - I lost $35 | Keith Lowdon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 46 | 11-13-2003 04:54 AM |
