Old 01-18-2012, 11:15 AM
Logichead Logichead is offline
Default TDM PCIx Cards in Magma AND Native Card in PCIe
Any idea if this will work? (Not at the same time of course...)
Details: A "Gainestown" 4.1 Mac with the Magma chassis running an HD3Accel PCIx system. Add a Native card to an open slot in the Mac.
Obviously, Native card will ignore the Magma, esp. if it is turned off.
What about the TDM rig? Will it run even though there is a Native card in the computer?
Best...H
Old 01-18-2012, 11:46 AM
Drew Mazurek's Avatar
Default Re: TDM PCIx Cards in Magma AND Native Card in PCIe
Yes, it works as you think. TDM will ignore Native, but Native needs chassis to be turned off. This was the behavior when I demoed the Native card a few months ago.
www.drewmazurek.com
Old 01-18-2012, 12:18 PM
the dude's Avatar
the dude the dude is offline
Yes I've installed this before
Just turn off the chassis and reboot to make the transition from HD into native Hd
You. Will need to move a cable Attached to the IO from the HD card to the native card
But it's painless
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 01-18-2012, 06:45 PM
Awesome. Nice to have this option. Thanks for the help!
Best...H
Old 01-20-2012, 04:54 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Nice for true comparison of your system.
Have you tested a maxed out HD3-Magma session.. does it open with headroom and remain responsive in native?
If so would you retire the HD3-Magma from your system?
Or is this solution for TDM-Only plug-in access?
Undecided Hardware-route up-grader (Native, HDX, Hold)
T
MP 12 core 12GB HD10, HD3s-Magma, OS 10.7.2
HD TDM Accel Number of voices per card both PCIx & PCIe Electric Peak Pro Tools TDM Systems (Mac) 15 01-26-2014 08:33 PM
AVID HD Native Card with ProTools HD9 Auth and Magma PCIe Chassis - $1500 UnkleMik Buy & Sell 2 06-03-2013 04:14 AM
Upgrade quandry - are new PCIe cards faster/better than old PCIx? ajmogis Pro Tools TDM Systems (Mac) 2 04-12-2011 08:33 AM
Where can I find a list of qualified Magma Chasis for PCIx to PCIe? a2zproductions Pro Tools TDM Systems (Mac) 21 01-14-2011 02:09 PM
PT 8.0 PCIe Core and PCIx Accel Card? Falk Pro Tools TDM Systems (Win) 1 10-14-2009 01:09 PM
