Old 10-26-2010, 10:53 PM
ericsvizeny ericsvizeny is offline
Default Installing HD 1 Core Card (PCIe)
I just purchased the PCIe HD 1 Core Card, I have a Mac Pro (Early 2009) I have two video cards installed in the computer. I read the instructions on installing the card correctly and it tells me to place the HD 1 in slot two (which is being used by my 2nd video card) Does it matter if I install the HD 1 core card into slot 3?
Thanks alot!
Eric
Old 10-27-2010, 01:08 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Installing HD 1 Core Card (PCIe)
Thanks alot!
Eric
Yes it should be fine in slot 3!
There's a possibility of a conflict with the second graphics card, but you'll soon know.
Do you have 2 graphics cards to have 4 monitors? i know there have been some problems with 4 monitor/2 graphics card setups in the past!! maybe thats fixed now.
Any problems remove the second card and try running without it and with the core card in slot 2.
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-27-2010, 06:14 AM
Originally Posted by crizdee View Post
Chris
No, i'm only running 2 monitors. I think I should just try slot 3 first and see it it works.
Old 10-27-2010, 07:04 AM
crizdee's Avatar
You'd be better off getting a dual head graphics card! are you sure the graphics card doesn't have dual head capabilities? lots of the more recent graphics cards have dual display outputs.
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-27-2010, 07:24 AM
drenkrom drenkrom is offline
I just thought of an SLI MacPro setup for a moment there and had a semi.
Using one dual-head GPU would make more sense indeed, especially since the MacPro's have one, single, lonely x16 PCIe lane. That second card is probably running at a fraction of its capabilities anyways.
Just a thought, really. The card should work in slot 3 as Chris said.
Chris
It is dual head, my 2nd video card isn't being used. Should I just take it out and put the HD 1 in the 2nd slot?
Old 10-27-2010, 07:25 AM
Sounds good, I'm think im going to try putting the HD 1 in the 3rd slot first.
Old 10-27-2010, 07:28 AM
crizdee's Avatar
If its not being used just take it out. less heat and less likely to cause conflict
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-27-2010, 08:25 AM
Chris
Very true!
PT HD1 (core card PCI) x PTHD1(Accel core card PCIE) Alécio Costa Pro Tools TDM Systems (Mac) 6 05-02-2017 06:52 AM
FS. HD1 Core card PCIe - £499 ! Ru_C Buy & Sell 1 09-09-2013 02:11 AM
Using a PCIe core card as additional Accel card? Firechild Pro Tools TDM Systems (Mac) 3 07-30-2012 10:48 PM
Is the HD Core PCIe card more powerful than the HD Core PCI? gearhead2010 Pro Tools TDM Systems (Mac) 2 08-07-2008 11:34 AM
Is every HD Core PCIe card an Accel Core Card? Matiz Pro Tools TDM Systems (Win) 3 06-11-2006 09:05 PM
