Old 03-09-2007, 08:35 PM
LindsayM LindsayM is offline
Default Problem with Uninstall of LE
I am trying to unistall LE that came with M Box 2. Using Add and Remove Programs, I get this error:
>setupdll\setupdll.cpp (469)
PAPP:Pro Tools LE
And some computerese.
I click OK and get Setup has experienced an error. some useless suggestions, and Error code: -5005
I want to uninstall just to reinstall because the original install was corrupted by a Microsoft Update that was pushed at the same time.
Thanks!
Lindsay
Old 03-11-2007, 03:10 PM
steve at Your Heaven steve at Your Heaven is offline
Default Re: Problem with Uninstall of LE
Use the JUMP button below, and post your question (and try a search) on the correct LE forum - this TDM forum is for different hardware, so we're not familiar with issues like yours.
I'm not sure if my guess is right, but if installing the same version anyway, you may not have to uninstall first - you might just try it and see if installing over the previous one will work (there may also be a 'Repair Installation' option in Add/RemovePrograms, which could work)
steve
Your Heaven
Old 03-11-2007, 04:04 PM
Avid's Avatar
Avid Avid is offline
Administrator
moved to LE forum
Administrator
PT LE v8 uninstall/reinstall reg problem jaycloidt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-27-2011 10:59 AM
Desperate For Help With PT Uninstall/Reinstall Problem. PLEASE HELP. URGENT! epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-20-2009 06:28 AM
uninstall problem rooney2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-08-2009 08:25 AM
install/uninstall 7.4 problem Dean Smith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-19-2008 07:21 AM
Clean Uninstall problem / help! modemdavid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-13-2007 04:26 PM
