Batch File Name/Volume Changes-How To?
Hello all,
Two questions: 1. Does anyone know how to make batch changes to the names of sound files. I would guess that this would be an OS level change instead of within Protools. I have a hundreds of effects that need to have the names changed to remove the first 5-6 characters and replace them with two characters so I can search through things more easily. 2. All of the effects are normalized to full volume. Is there a way to make a batch change to all of them to reduce the level so they don't blow me away when they are auditioned? Thanks! |
Re: Batch File Name/Volume Changes-How To?
The Command Prompt's RENAME command allows renaming groups of files in the same folder with use of the ????????.??? and *.* specifiers. Experiment on a few copies in a temporary folder to see if it will do what you want. Also, Google "rename group of files" to get some utilities that may be easier and/or better. 2. All of the effects are normalized to full volume. Is there a way to make a batch change to all of them to reduce the level so they don't blow me away when they are auditioned? I'm not at a machine so can't check, but there may be a setting for preview volume some where. If not, and you can't just turn down the sound somewhere, you can import them all into a Protools session, use the Audiosuite "Gain" plug in to reduce them all by (eg) 20 db. This will write new files so you still have your old ones. Use the new ones to audition, then use the old full gain version in the session.
steve Your Heaven |
Try Flash Renamer: http://www.rlvision.com/flashren/about.asp
If I need to rename a bunch of files in Pro Tools, Strip Silence is the way to go. PT7 added a feature in there called 'Rename' and it is very handy.
Thanks everyone for the suggestions, but Rail's Flash Renamer was the winner! Great little app!
How can I "batch" export each region as separate audio file? | Screenery | Tips & Tricks | 1 | 05-03-2008 10:12 PM |
Need a batch file Renamer App?? | minister | Post - Surround - Video | 6 | 08-20-2006 10:28 AM |
Batch rename file types? | jonnyrocker | Pro Tools TDM Systems (Mac) | 4 | 04-22-2006 03:17 PM |
batch sound file converter for OSX? | JR Fountain | Post - Surround - Video | 9 | 05-03-2004 07:33 AM |
How to batch convert SDII to other file-types? | PeterScherr | Pro Tools TDM Systems (Mac) | 10 | 07-01-2003 10:39 AM |
