XPand2 Preset Patches are Missing?
When I launch the plugin the presets are missing, where do they usually live on the hard drive after they're installed?
This directory is on my computer put there's nothing in it: C:\Program Files\AIR Music Technology\Factory Content\Track Presets\Avid\AIR Instruments Bundle\Xpand!2 I DO have this .big file in this directory: C:\Program Files\AIR Music Technology\XPand2\XPand2.big The individual elements are there in the plugin but no presets. Perhaps I just don't know how to select a preset? The manual says the box at the bottom will show the Preset Patch and there should be a save icon but mine shows no patch name and it just shows a wrench. Any help would be appreciated. Thanks!
Imac Late 2013 2.9 GHz Intel Core i5 8 GB 1600 MHz DDR3 OS 10.11.2 PT 12.4.0 |
Re: XPand2 Preset Patches are Missing?
Hi
I had seem this in the past locate and remove all xpand files and plugin manually the install the lastest version . This shold fix the problem .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
jeam25 I also present the same problem. And I uninstalled and installed and not work at all the presets only. Any idea?
Xpand presets are in your user documents folder: C:\Users\xxxxx\Documents\Pro Tools\Plug-In Settings\Xpand!2 or Mac equivalent.
Track Presets for Xpand are here: C:\Users\xxxxx\Documents\Pro Tools\Track Presets\Avid\AIR Instruments Bundle\XPand!2 You need to install a 2018 version of Air Instrument to have the Track Presets installed. Presets and Track Presets are two different things. The .big file is the samples used by Xpand and if not found, the plug will open a dialog to locate. As mentioned, a reinstallation should correct if those folders are missing.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
I installed AIr collection 11.3 over the latest version and everything is working now. What happened that? Installing and uninstalling latest version doesn’t make appear presets but installing 11.3 appear, strange not?
Xpand2 patches missing! | iamkimosabi | macOS | 1 | 06-07-2012 11:37 PM |
XPAND2 missing my patches and presets | iamkimosabi | Virtual Instruments | 1 | 06-07-2012 11:34 PM |
xpand2 preset question | bryced87 | macOS | 5 | 08-13-2011 10:20 AM |
Getting Rid Of Delay On XPand2 Patches | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-05-2009 08:29 PM |
Xpand2 Patches - The Monster Set! | RussUK | Virtual Instruments | 7 | 01-20-2009 08:20 AM |
