Old 05-28-2004, 10:42 AM
MR808 MR808 is offline
Default grouping together audio regions
Is there a way to group selected audio regions only ...(example I have a 2 part-Hook that i need to copy and paste thru out the song. I used 4 tracks recording the hook, some times only one part of the hook will be copied and other times both will be recorded.)....
Also is there a way to export tracks, with out using the bounce to disk... (example#2.. I have a song that consist of 12 music tracks and would like to just export them to a new stereo mix and make the 12 track inactive... is this possible without using the bounce to disk)
Last, is there a way to set up a loop in pt and turn it on and off... instead of having it to change every time u drag in the timeline?
Old 05-28-2004, 10:56 AM
soundsurfr soundsurfr is offline
Default Re: grouping together audio regions
Under the group list select <ALL>. Highlight one region of the hook and all regions will be highlighted. Copy and paste. Deselect <ALL>
Soundsurfr
MAC Mini, 2.3GHz dual-core i5, 8GB DDR3, 500GB Hard drive, 288MB DDR3 SD RAM
M-Audio Firewire 1814
Yosemite OS
Old 05-28-2004, 12:53 PM
GapeOne GapeOne is offline
Select the audio regions and hit ALT+SHIFT+3. This will make them 1 single region. Is that what you want?
If you're talking about audio regions on seperate tracks then I don't think you can do that, but an alternative method is to creat a GROUP for the 4 tracks you have the hook on (select all four tracks and hit CNTRL+G), select the group so that everytime you grab any audio region in any track of that group you will grab all respective audio regions on all tracks under that group.
Yes, but you'll still have to listen to the entire piece of music, which is what I believe you were trying to avoid, yes?
If not then the alternative method is to send the output of the selected tracks to a bus line and then open a new stereo audio track, set the input to that bus line and record. I believe they call this a SUB MIX, but I'm still trying to learn all the nifty terms so don't quote me on that...
Yup. Checkout PLAYLIST(S) in your PTLE reference guide. I believe that is what you are talking about. If not then my appologies for not understanding the initial question..
GOOD LUCK!
- GAPE
www.myspace.com/soulskool
Grouping crossfaded regions. is it a bug? RaToX Pro Tools 9 19 01-28-2011 12:52 AM
Grouping regions emerson625 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-16-2009 07:28 AM
Grouping Regions?? teacherman Tips & Tricks 11 11-15-2008 01:50 PM
grouping regions KHFohlert Tips & Tricks 2 09-11-2004 01:52 AM
Is Grouping Regions Possible? D Pinder Tips & Tricks 1 02-10-2000 11:28 AM
