Complete Format and reinstall? or any other idea?
Hi all,
I used to be able to work on PT sessions from the internal Macintosh HD drive. But now it gives me an DAE error -9060 -9031 and others instantly after hitting play. No problem with the external FW drive. I've done so far: - Check drive is set to R in Workspace - Clear Prefs and DB - Repair permissions in disk utility - Reinstall and update PT software 8.05 - Run Repair Disk in Disk utilities. The disk is HFS+ Journalled - Reinstall Mac OSX and update to 10.6.8 (without reformat) But the errors keeps appearing. very frustating because it worked flawlessly one week ago. Last resort would be a complete FORMAT. How should I format? Or can you suggest any other thing I should try before this drastic measure. (Backups are done) Thanks very much!!! |
Re: Complete Format and reinstall? or any other idea?
Are you saying you're getting the problems when just using your system internal hard drive for PT to Record to but not when using the firewire drive to record to? Why not just record to the external drive and leave the system drive to do it's original job of hosting the system stuff like programs?
Here's a link to an Avid page on dae 9060 errors: http://avid.force.com/pkb/articles/e...oductCategory= And here's a link to a page on the combo of 9060 and 9031 errors: http://avid.force.com/pkb/articles/e...oductCategory= Neither of these remedies entail reformatting your system drive. |
Hi thanks for the reply!
I know it's not recommended to use the internal HD, but these are simple sessions which used to perform just fine off the internal HD. A corrupt audio or fade file is also not the case here. The same sessions unplayable on Mac HD, play back fine on external FW drive. |
Sparky |
Just an update.
My solution to a problem is not to ignore it. We have 9 PT stations at our facility and all of them are perfectly capable of playing back a session off the internal HD. I can assume the performance limitation this may have but I can not accept when it does not work at all, giving all sorts of cryptic errors. Because it's an indication that something is broken. Thanks anyways, I finally reformatted and reinstalled all and it's working now. My guess is that the HD somehow got flagged as invalid for protools. |
Very simply, Avid does not support running sessions off the system drive. So I don't know how to offer help on a system that is not supported.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
PT 10 and later are a lot less fussy about this and configuration in general.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Still Avid had not and probably will not back off this recommendation. Either way it's not a good idea to run sessions off your system drive.
Errors after format and reinstall | A.P. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 02-10-2009 11:12 AM |
Format & reinstall, curiosity... | frankreverbo | Pro Tools TDM Systems (Mac) | 0 | 01-13-2008 02:35 AM |
complete reinstall.?? | manis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-20-2007 08:57 PM |
Help with complete uninstall and reinstall | z00story | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-22-2004 07:25 PM |
onboard sound, good idea/bad idea?! | sampb7 | Digidesign Hardware & Software | 1 | 02-22-2003 02:44 AM |
