Old 10-07-2019, 12:27 PM
MCDada MCDada is offline
Default Newbie with a problem connecting Midi Controllers
Hi everyone-
I feel like I've watched every tutorial and forum post about connecting a midi controller to Pro tools 2019, and nothing is working! I have a MPK Mini, and I'm running pro tools on both a mac and windows. I go into the peripherals tab and enable the slave (127) and midi thru is checked off, and on midi controllers tab I have M Audio- Input MPK mini ii (emulated) # channels 8. Some the the tutorials say something about input should be MPK mini Port B, but thats not an option for me.
Any advice would be greatly appreciated. I am comfortable with Ableton but I wanted to give this a try, but I'm on the verge of giving up!
Old 10-07-2019, 12:32 PM
Hi everybody-
I desperately need some help. I have watched several tutorials, read through forum posts, but I can seem to connect a Midi controller to protools 2019. I have a MPK mini. I have made sure the midi thru is checked, I have gone to the peripherals tab and selected M Audio Keyboard/MPKmini(emulated) for the input, and I have enabled the slave (127). I am an Abletom user but I wanted to learn Pro tools as well. This has been so frustrating and I'm close to giving up. Can anyone help?
Thanks
Old 10-07-2019, 01:15 PM
massivekerry's Avatar
massivekerry massivekerry is online now
Default Re: Newbie with a problem connecting Midi Controllers
On Mac, you need to have the device set up in the MIDI Studio of the Audio MIDI Setup app (in Applications/Utilities). Once it's there, it should show up in Pro Tools in the Setup->MIDI->MIDI Input Devices menu. If it's USB and you have the correct drivers installed, Audio MIDI Setup should see it.
Old 10-07-2019, 01:48 PM
ChuckS ChuckS is offline
You only set it up in Peripherals if it is a MIDI Control Surface, i.e. HUI, Mackie Control, etc. Your device is not a Control Surface. Unconfigure it in peripherals. The PT terminology is confusing.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 10-07-2019, 02:47 PM
So it should control the plugin without configuring it in PT? It seems like it should be just plug and play?
Old 10-07-2019, 03:13 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
What are you trying to control in PT? If it's just a VI, PT is set up to recognize all midi inputs as default but can be set up in prefs not to.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 10-07-2019, 04:03 PM
I'm trying to use xpand!2. I cant map the knobs or anything. I hit the keys and nothing happens. It was much easier with Ableton and Logic Pro
Problem connecting two midi devices in PT10 JesseLucuani General Discussion 1 03-08-2014 11:35 AM
Utility for connecting Steinberg CMC controllers to Pro Tools? t0nes General Discussion 7 03-05-2014 01:17 PM
connecting multiple usb midi controllers crache macOS 2 06-15-2013 08:32 AM
Newbie Question - Patches and Controllers hyphen8 MIDI 4 08-08-2002 12:48 AM
problem with MTC-SMPTE-MIDI controllers Natural Sound Tips & Tricks 24 08-28-2000 04:50 AM
