How low is "Low Latency Mode" in HDN??
For example:
At 96kHz Buffer 64 = 1.8ms Round Trip (RT) Buffer 128 = 3.12ms If I engage LLM does anyone know what RT latency is reduced to?
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html Last edited by propower; 09-26-2013 at 10:55 AM. |
Re: How low is "Low Latency Mode" in HDN??
I broke out the oscilloscope and function generator and answered my own question
Using an input on an Avid 16x16 and an output on an OMNI and measured time delay from Analog in to Analog out. 96kHz I/O RT 64 samples ---- 1.80ms 128 ------------- 3.12ms 256 ------------- 5.8ms 512 ------------- 11.12ms LLM ------------- 0.47ms (regardless of Buffer) 44.1kHz I/O RT 32 samples ----- 3.35ms 64 --------------- 4.80ms 128 -------------- 7.68ms 256 -------------- 13.52ms LLM -------------- 1.9ms (regardless of Buffer)
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Thanks for sharing.
Is it possible to measure the time delay for direct monitoring ? |
What is "direct monitoring"?
And so sorry - I am using a Mac system and mistakenly put this in the Windows forum. I did measure the Low Latency Monitor path (LLM) and it is the lowest 96kHz performance of any interface I know. Is that the "direct monitor path" you are referring to?
True direct monitoring should have zero delay since that implies all signals are in the analog domain. So, if you are monitoring with headphones, you won't have any delay. If you are monitoring with speakers, then the delay will depend on how far away you are standing from the speakers.
Hope this helps, Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
With most interfaces, including HD Native, direct monitoring, or low latency monitoring, is basically a function where the interface acts like a normal analog mixer. The signal from your input goes directly to your output, without going through the analog to digital and digital to analog conversion that introduces delay (although it still does this as well, but you're not hearing it while it happens in this mode, it's basically going both ways).
Most interfaces have software that allows you to set this up, such as Focusrite's Mix Control software, or Apogee's Maestro software, etc. For HD Native, it's just done as a choice in the I/O setup when Protools is open. |
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Pretty sure that the LLM mode in ProTools, which bypasses plugs and paths for a selected record channel and routes it to the LLM path (i.e., headphones) is only available on HD OMNI, Digi002 & 003 series). Is that right?
Regards, Matt
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
almost, it is not specific to hardware such as the Omni as it is just a converter, not an actual interface like a 002/003. In that case it is specific to the "audio card" the interface is hooked up to. In the Omni case it would be an HDN or HDX.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
So LLM (as seen in the 'Options' when using a 003 for example) is available when using a 16 I/O?
Edit: Nevermind! ;-)
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 Last edited by mattrixx; 10-15-2013 at 04:32 PM. Reason: stupid question! ;-) |
i have a problem with "Pencil Tool". Why it's always in "square mode" ? | ak11_lin | macOS | 6 | 08-25-2013 05:38 AM |
Switching a HD from "transfer only" to "record mode" | BretFarewell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-16-2010 12:49 PM |
Switching subwoofer from "discrete mode" to "stereo mode"? | Slerker | Post - Surround - Video | 6 | 02-11-2009 07:04 PM |
downsides to "low latency monitor" mode | jacko32 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-16-2003 12:27 AM |
So Where is this ""WIN2K COMPATABILITY MODE""?? | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2002 03:30 PM |
