Old 10-22-2019, 03:56 PM
ramonetl ramonetl is offline
Default Re: Intel Core i5 vs. i7
Originally Posted by Prabha View Post
i7 is obviously better, but I do run a commercial studio everyday on an i5 6600K.
It runs smooth and solid when tracking 17 musicians and doing 7 monitor mixes plus the studio mix at a buffer of 64 samples. no hickups.
I do also mix large (+80 tracks) sessions with plenty of plugins, at a 256 buffer at most.
What OS and PT version are you running on that? Just curious where your sweet spot is.
Old 10-22-2019, 03:57 PM
Originally Posted by Bob Olhsson View Post
I understand the difference is that i5 doesn't have hyperthreading.
HMM I have seen a lot of comments when I was having cpu crashing where folks suggested disabling hyper-threading for better performance.
Old 10-23-2019, 05:32 AM
Prabha Prabha is offline
Windows 10, and PT 2019.5.
SSL MX4 madi card. (I believe the drivers are important)
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Old 10-23-2019, 05:39 AM
JFreak JFreak is online now
Not for better performance, but in some circumstances some plugins work less effectively when hyperthreading so if that is the case, disabling HT will help.
Not a silver bullet though. In general (as in most processes have some idle time every now and then) enabling HT makes things more effective because it makes it possible to take advantage of those idle times.
Though if there is no idle time, HT makes performance worse because the additional process, for simplicity let's call it a dispatcher, has more work juggling processes to real working cores and eventually the dispatcher is asking the processor for more than it can handle, therefore stopping playback.
Old 10-23-2019, 07:57 AM
TOM@METRO's Avatar
I'm one of them. On my main rig, disabling Hyperthreading has reduced errors and spiking.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-18-2021, 06:05 AM
markf1 markf1 is offline
I'm new here still learning the ropes so hopefully I'm in the right place but just wondering
I'm putting together a computer to run the latest pro tools I'm looking at :
windows 10 home 64
10th gen i5 @2.9 10400
32 gig ddr4 ram
1tb ssd hd os
500gb ssd hd internal dedicated for bfd3
gigabite 210 motherboard
pro tools 2020.9 or latest version?
usb3 inputs
will this set up be ok with the fast ssd drives or should I opt for an earlier version of pro tools or an i7 may be??
thanks
Old 02-18-2021, 07:05 AM
Default i5 v i7
I'm putting together a computer to run the latest pro tools or earlier I'm looking at :
windows 10 home 64
10th gen i5 @2.9 - 4.8 10400
32 gig ddr4 ram
1tb ssd hd for o/s
500gb ssd hd internal dedicated for bfd3 core samples
pro tools 2020 or latest version?
usb3 inputs
thanks
Old 02-18-2021, 08:15 AM
ejinbc ejinbc is offline
Default Re: i5 v i7
M
Knowing nothing about your needs/budget...
See the attached chart. I would highly recommend you spend the extra couple hundred dollars on an i7. For Pro Tools you will find a meaningful (significant) difference - both single core and multicore performance. Also, this chip should overclock to 4.9 GHz easily which will make for a stable / powerful system with Turbo Mode and C-states OFF.
Hope that helps.
e
Old 02-18-2021, 08:30 AM
windows 10 home 64
32 gig ddr4 ram
1tb ssd hd os
usb3 inputs
thanks
Just me, but I would opt for i7 and a faster clock speed(like 3.4GHz or better). It costs more up front, but the system will last longer(because you won't out-grow it) which makes it a better value.
Old 02-18-2021, 08:32 AM
Default Re: i5 v i7
Just me, but I would opt for i7 and a faster clock speed(like 3.4GHz or better). It costs more up front, but the system will last longer(because you won't out-grow it) which makes it a better value. Good advice above too. More speed is better than more cores
Macbook Air 2014 (1.4ghz Dual-core Intel core i5 Vs. Mid 2010 MBP i7 Quad-Core and PT TheGoodhusbands Virtual Instruments 2 09-11-2015 10:49 AM
FS (EU): MacMini 2,6 GHz Quad-Core Intel Core i7 + Focusrite Saffire PRO 24 DSP Delta Music Belgium Buy & Sell 1 04-17-2015 10:22 AM
HDX-2 on (slightly revised) 12-core 2 x 2.4GHz 6-core Intel? / RTAS in PT10HD MixerGuy Pro Tools HDX & HD Native Systems (Mac) 10 06-18-2012 07:10 AM
Intel Core i7 2.0GHz Quad-Core Processor or Intel Core i7 2.7GHz Dual-Core Processor? okodub Pro Tools 9 3 09-23-2011 07:33 AM
XPS 410, Intel Core 2 Quad Core Processor Q6600 mzampi1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-14-2007 04:14 PM
