Old 12-15-2007, 10:53 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: THAT AGGRIVATING WHITE NOISE!!!!!
Digidesign receommends you DO NOT defrag, but rather copy the files from the audio drive, format the audio drive with a cluster size of 32 k (or even 64 k) and then copy the files back. And 25 gigs left on a 250 gig drive is way too full. You need to archive some or a lot of those sessions so you have (lots) of room on your audio drive. You probably don't want to get beyond 70% or 75% Used Space. As the drive gets full the heads have to work harder just as they do when the information is defragmented. Drives are way cheap these days, no need to use every last byte.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-15-2007, 10:55 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
it helped some but I really think it may be a bug in7.4 b/c I didn't have the prob til then; I've trashed everything, I defrag my drives on a regular & it has nut'n to do with buffer;I don't have any demo plugs & it still happens; on certain sessions now but its there even if its jus one session why is it there....
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-15-2007, 09:23 PM
TNDoug TNDoug is offline
Buffer size is set at 1500 ms; Lever 2 (default) with cache size = "normal". H/W buffer size is 512 Samples, 4 Processors and CPU Usage limit is set to 85%. I am defragging my C drive overnight and have moved 50 GB of session files off of the audio drive. I have been recording to this drive for 2 years without any previous issues.
Thanks again for your help
Old 12-15-2007, 10:40 PM
Bharath's Avatar
Bharath Bharath is offline
You probably tried this already. But, if you move or copy this session to a different drive, preferably internal, does it go away?
Thanks
:: Bharath
Pro Tools Software Team
Old 12-17-2007, 03:37 PM
DigiTechSupt's Avatar
Could we possibly get a copy of the problematic session?
You can send a link to transfer [at] digidesign [dot] com. Please reference this thread in the message.
If you need DigiDelivery information to send us the session, please let us know by sending an email to the address above.
Avid Audio Tech Support
Support FAQ
  #16
Old 12-17-2007, 05:05 PM
msg6794 msg6794 is offline
Default Re: THAT AGGRAVATING WHITE NOISE!!!!!
i believe i'm having similar problems. i'm pretty certain it's not session-specific. the reason i think this: my dell came with windows xp on it. protools 7.3 ran great on it. when 7.4 came out, i upgraded in xp and it still ran great. so i figured it was finally time to go to vista. (this is on the original mbox, fwiw.)
i removed my xp system disk and installed vista from scratch on a brand new drive, so that if anything went wrong, i still had my xp system ready to go. i installed 7.4 in vista, got all my plugins finally set up.
now, when running the same exact sessions, running from a secondary internal data drive, i experience this static noise intermittently, which almost sounds like scratches and pops on vinyl, but only when running the sessions from vista. it's not always in the same place on playback, and there are little specks of the noise during recording, and it gets recorded to the track. however, when i put the xp disk back in, and run the same identical session, there is no noise on playback (beside the noise on the tracks that got recorded while in vista).
please fix this, digi!
003 Rack | Dell Studio XPS 8700 (Core i7 4790, 16GB RAM) | Windows 10 64-bit / PT 12.6
  #17
Old 12-18-2007, 08:20 PM
Hey guys I sent one of the few sessions that i'm having that problem with from my YOUSENDIT acct. its in to different emails b/c its over 2gig so i split in in half; it's called WE'VE COME....
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
  #18
Old 12-19-2007, 05:40 AM
The most frustrating issue with this bug is that it occurs mostly during playback but doesn't actually get written to the track. However, occasionally it does get recorded like this clip right here. MP3 of White Noise in session file . Since I have moved 50 GB off of my audio drive I have not had this problem.....yet.
Thanks for your help,
Doug
  #19
Old 12-19-2007, 06:57 PM
Sadly, this beast has reared it's ugly head in my latest session. This time I was able to determine that the noise is occurring on the record enabled track because I had a vocal aux bus track with reverb in the mix. When the white noise occurred, I could hear the reverb on it. It did not record on any of the tracks but played back in random placed during several takes before I shut it down for the night.
I hope you can find a fix soon.
  #20
Old 12-19-2007, 10:15 PM
One of the sessions I really needed a fix on I dragged it to another drive & it stopped; however, when I made a new session & imported it to that drive I still had it...don't know...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini Bigpit Windows 1 09-09-2013 09:26 AM
Burst of noise (not necessarily white noise) at the end of clips Swarf macOS 9 09-20-2012 08:55 AM
Static noise (aka White noise ) During playback. =/ PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-23-2010 04:06 PM
simple question,BUT aggravating! S_w_a_m_p 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-28-2009 12:29 PM
Pink noise vs. White noise kcarter Tips & Tricks 9 08-29-2001 10:42 PM
