Shortcut to focus plugin in D-Command?
When i mix, i always use the following shortcut to open a plugin window to see what's going quickly on a channel: CTRL + select on a rotary encoder in insert mode. This brings the window of the plugin in Pro Tools. Quick for navigating thru plugins. But is there a shortcut to open this plugin in focus mode (Plugin focus) on the console? The quickest way i know to do this is to select the track, press plugin in the custom fader switches and the cycle until i get to the plugin i want to tweak. Is there a "one click" shortcut to do this? Thanks! Luc |
Re: Shortcut to focus plugin in D-Command?
Unless I am not understanding you correctly..... you simply press select on that insert and that plug is instantly focused.
What i mean is to focus the plugin on the custom faders. When i press select, it focus the plugin on the rotary encoders from that channel. EQ's and compressor are focused on the master section if i select that channel but i dont know any way to select a plugin on a channel (lets say decapitator on channel 15) and automatically open this plugin on the custom fader bank. Thanks! |
You need to turn off Channel Plugin Mode in the Operations menu of the D Command.
How come i never tried this... Ok, one more: If i am on the custom fader (VCA) page and i spill my drum master VCA, then i select a plugin on the kick track, when i exit the plugin page, it will return to the custom fader (VCA) page. Is there a way to return to the previous state (the spilled drums)? Thanks again! |
Command Keyboard Focus mode ' E ' command bug ? | vudoo | Pro Tools TDM Systems (Win) | 2 | 09-10-2009 05:49 AM |
D-Command - Trim Plugin to Focus channel | nd | ICON & C|24 | 3 | 07-21-2009 04:35 PM |
Command Focus shortcut sticker for = key (num pad) | Karl Engel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-19-2006 10:42 AM |
Commands focus keyboard shortcut | Paul Maunder | Tips & Tricks | 1 | 03-19-2005 05:14 AM |
Is there a shortcut to turn on/off commands-focus? | cc1 | Tips & Tricks | 1 | 09-05-2004 12:16 AM |
