Pro Control Mounting Brackets
I am in need of two sets of these. Anybody out there have any you want to sell.
Or, is there anyone who is willing to let me rent theirs for a week so I can use them as temple to have them fabricated?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Re: Pro Control Mounting Brackets
- remove the fader panels of each unit (disconnect all faders and connectors of the upper PCB's) - at both sides of a main unit or a fader pack there are some holes pre-drilled (you can attach the plastic sides of main unit here) - use a metal drill to enlarge these holes on all the units that touch each other (I left the outer holes untouched so I could reattach the plastic sides) - bolt each fader pack or main unit to the next one - replace the fader panels of each unit (reconnect all the faders and all the connectors of the upper PCB's) It sounds difficult, but in fact it easy to do and this method works very well (IMHO it is stronger then using the mounting brackets). But still all the units needs to be supported by a frame or desk. Only bolting them together is not strong enough (neither are the mounting brackets). In my case (48 ch.), I used a large wooden plate supported by multiple mixing desk stands stands to support the entire 48 ch. ProControl. I also lifted the back side of the entire ProControl a few inch because I liked it that way (it's more ergonomic) Maybe in your case (24 ch) only bolting them together and supporting them with a simple mixing desk stand could be sufficient, but I would advise to make it as sturdy as possible (people tend to lean on mixing desks, so make sure it can handle it)
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
WTB Pro Control Mounting Brackets | Barry Johns | Buy & Sell | 0 | 04-25-2014 11:01 AM |
WLTB: Pro Control Fader back Mounting brackets | DigitalMetal | Buy & Sell | 1 | 09-09-2013 04:17 PM |
Brackets | Larold | ProControl, Control|24, Command|8 | 1 | 11-14-2011 08:32 AM |
Monitor mounting on D control | Rollerex | ICON & C|24 | 5 | 07-11-2004 09:08 PM |
