Need some help setting up ProTools to record with Eleven Rack
So I am brand new to ProTools. I just bought a new Eleven Rack, have ProTools 10 and I'm trying to figure out how to start recording. Found the page in the manual, but where I run into the problem is that even though the Input Selector says "Eleven Rig L/R", it's dark as though it's not active. If I click on it, it has "no input" checked off and the only options available under interface are "built-in microphone (stereo)" and "built-in input (stereo)". I can open up the editor window and edit patches fine, but for some reason I can't get it to record. I'm sure it's something very simple to fix, I just can't figure it out. I'm just going in by USB by the way.
Re: Need some help setting up ProTools to record with Eleven Rack
http://www.youtube.com/watch?v=-Rjk5qVFEE8
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Unfortunately this didn't work. When I go into the I/O window, Eleven Rig doesn't even show. I defaulted both and still nothing. Any other thoughts?
Assuming you're on Windows and only using the 11R as an Interface;
With the 11R switched on, go to Control Panel>Device Manager>double click Sound Video and Game Controllers. There should be two entries 1.Avid Eleven Rack 2.Avid Eleven rack RT DFU If they are not there, re-install the drivers; http://avid.custkb.com/avid/app/self...3=1450&Hilite= Install with 11R switched off then reboot with it switched on. Even if the entries are showing in device manager, it wouldn't hurt to re-install the drivers anyway as they may have been corrupted. Once your drivers are installed go to Pro Tools>Setup>Hardware. Your 11R should be showing up there. Also check that it is selected in PT>Setup>Playback Engine. Then go to Setup>I/O>Input Tab>click Default>Do same on Output Tab >OK. BTW, I'm pretty sure the drivers need to be installed BEFORE installing Pro Tools (versions 9 & 10 anyway).
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
You need to set the Eleven Rack as your Interface for Pro Tools. do as Zed said and make sure you have the drivers installed. What OS are you using?
I don't actually remember physically installing drivers for the Eleven Rack, but would I be able to edit with the Editor if they were not installed? I'm using OS X Lion and this is the only device that ever been hooked up to the computer aside from my HD500, but I didn't have any recording interface installed before I installed ProTools yesterday.
Sounds like you already have the drivers installed, but you can always double check and make sure they are up to date. http://secure.digidesign.com/service...&localeCode=en
No dice, re-installed the drivers, punched N on starting ProTools, I chose Eleven Rack as my device, but Eleven Rig L/R is still dark in ProTools. Any other thoughts, this is killing me!
Something new is happening though, now when I start ProTools, it does show that it's reading something off of the Eleven Rack at startup and it also kills the sound on the Eleven Rack now when ProTools starts up. Before it would not effect being able to play through the Eleven Rack when I started ProTools.
Setting up Eleven Rack with Korg DTR-2??? | erikhimel | Eleven Rack | 2 | 02-01-2014 12:43 PM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Can't record from my Eleven rack into protools 10 | KirbyD | Eleven Rack | 1 | 03-01-2012 08:04 AM |
Sound problems in ''record mode '' Eleven Rack + ProTools 8 | Musicfreak | Eleven Rack | 5 | 02-07-2012 05:58 AM |
Setting up Eleven Rack on Mac OS 10.6.3 | stratman.0426 | MIDI | 1 | 05-21-2010 01:16 AM |
