Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-27-2011, 04:09 PM
juicytunes juicytunes is offline
Default Hard drive pre- intel, post- intel
Not sure which category this should be in.
Have a glyph hard drive I used with my pre-intel G5. Just bought a new imac.
Will I be able to use the same hard drive to record, or do I need a new one?
Old 11-27-2011, 06:26 PM
Kasper Kasper is offline
Default Re: Hard drive pre- intel, post- intel
Should not be a problem, although a modern drive will most likely be much faster than a G5 era drive.
I would reformat with Disk Utility. (assuming you don't need the data on it)
kasper
Old 11-27-2011, 07:38 PM
Thanks Kasper.
I'd rather not lose the data. I guess I could transfer it to internal drive, reformat, then return it to glyph drive. Or, just buy a new one.
Old 11-27-2011, 08:34 PM
Given it's age, if there's anything of value on that drive, I'd back it up somehow. Bly-ray, DVD, another HD.. something.
Doesn't happen often, but when a drive fails, it can be disastrous ... juz sayin'...
And with the Glyph, you're paying for the case anyway. If the chipset in the enclosure will support a large size drive, crack it open and put a new HD in the Glyph ..... my 2c.
kasper
Old 11-28-2011, 08:19 AM
It's not as old as the G5 was. I bought it at some point when the older drive started to fail. But, probably 2-3 years old maybe?
On another note, if my interface ( just bought the mbox pro ) is firewire, should I get a firewire drive and run in line, or make sure to get a usb drive? Does it matter? The glyph has both.
Old 11-28-2011, 10:02 AM
It's probably just fine, but I'd still back up your important stuff.
Not really my area of expertise, all my drives are esata, but firewire has always been better than USB. I think USB is specifically NOT qualified for use with PT (although that may be changing)
kasper
Old 11-28-2011, 12:14 PM
kasper
Have to agree. Plus, you likely want the drive reformatted anyway as it may be FAT32 and you need to be HFS+ with your new Mac. Transfer all the files to another drive, reformat(or replace the drive as suggested) and copy the files back afterwards.
Old 12-01-2011, 11:06 AM
thanks guys. Any preferred hard drives?
Old 12-01-2011, 11:34 AM
For raw drives, the WD Caviar Black are a popular choice for recording. Larger versions have a 64MB cache, but the 32MB is plenty decent
Old 12-01-2011, 01:54 PM
Well, I realized, I started off this thread with incorrect information.
My current external drive is a G drive, not a glyph. Brain fart.
Anyway, bought another g drive as well today. Figuring I can record to the new one and backup to the old one, or vice versa.
Is it advisable to have the virtual instruments on and external drive as well?
Intel core duo incompatability- External hard drive(lack of) freeskiboy Pro Tools M-Powered (Win) 1 05-28-2008 08:52 AM
Intel G33 Chipset & Doogz & Can't Find His Post & Pro Tools Willosy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-30-2007 07:15 PM
Protools doesn't start up on new MiniMac intel, Imac Intel,. Lennert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-14-2007 01:17 PM
Two Graphics cards in an Intel MacPro 8 Core for Post joepopp Post - Surround - Video 5 10-23-2007 04:05 PM
Intel® 915P Express chipset and the Intel® Pentium darkglass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-23-2005 06:05 PM
