problems with midi editor and tempo
Hi this has happended to me twice now...: I record some stuff after a click, then add drums using xpand! and construct the beats manually in midi editor. then when I close the editor, suddenly the grid is either gone, or Is in another tempo/meter. and the click track is off as well, although the correct tempo/meter is still showing. the click even changes tempo during playback after this last time. VERY frustrating, as it destroys the entire session and, It doesnt matter if I load a backup file from before i added drums. the error still resist, even after restarting pro tools. This has only happened when I`ve used "odd" time signatures.
what to do? btw. pro tools 8le windows xp |
Re: problems with midi editor and tempo
now I`ve reopened the last track this happened with, wich I had fixed by doing everything all over again. but now it was all messed up again. Then i tried something new.. I tried lowering the buffersize:) It worked I thought the buffersize was supposed to be high when you try to playback something that was already recorded.. but hey.. problem fixed
Eleven Rack standalone Editor: Can it "lock hardware tempo to session tempo"? | ToddnTodd | Eleven Rack | 17 | 02-02-2014 02:29 AM |
XPand!/midi editor destroys tempo and grid | moosebox | Virtual Instruments | 1 | 04-01-2011 02:15 PM |
Zoomer Problems in MIDI Editor | ralphie3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-30-2009 02:37 PM |
Midi Recording Tempo Problems | LucasM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-25-2007 07:34 PM |
