D-Command - Trim Plugin to Focus channel
Hi all!
I'm trying to get my head around this complex console. Am I able to somehow have a tracks trim plugin "gain" parameter assigned to a fader? Am I able to do this at the same time as having the tracks regular volume on the fader next to that one? The reason I want to do this is I'm mixing dialogue and there's a vast dynamic range. I'm maxxing the fader gain often and then going into the gain plugin and automating more gain where I need it. It would be nice to be able to automate the gain plugin using the fader next to the one I'm riding. I realise I could make an aux track next to it, but I'm all for less tracks in the session and want to learn more about utilising the D-Command. Thanks! |
Re: D-Command - Trim Plugin to Focus channel
In Operations turn on Chan PI (channel plugin mode) and you can have the Gain parameter on an encoder above the fader.
I think we're looking here at a typical scenario of a 'custom fader' setup.
Had to look this up from the manual for D Command. You may want to do the same ... page 122 in the PT8 version of D Command. Anyhow ... the idea is to have multiple copies of the same channel in that 'custom' group. In your example you could do with 2 duplicates of the tracks you're automating. 1 fader controls volume .... 1 fader controls the gain parameter of the 'trim' plugin 'flipped' to a fader. 2 adjacent faders doing exactly what you want ... Hope that helps. Chris Quote:
Chris Lambrechts Applications Specialist- Live Sound |
That sounds like the deal.... how do I get the gain parameter flipped to a fader? |
command focus | Macsearcher | macOS | 2 | 02-26-2014 02:21 PM |
Command Focus Lag | BobbyDazzler | macOS | 0 | 09-15-2011 07:04 PM |
D-Command: possible to FOCUS a channel from PT software ? | bennym | ICON & C|24 | 3 | 01-23-2011 05:52 PM |
Command Focus bug? | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-27-2009 05:31 PM |
Command Keyboard Focus mode ' E ' command bug ? | vudoo | Pro Tools TDM Systems (Win) | 2 | 09-10-2009 05:49 AM |
