Problem Syncing Digimax FS with 002 Rack
Hello,
I just got a Digimax FS and am trying to get it synced up with my 002r. I have both optical lines run, and the Digimax is set to External ADAT sync, and it shows the correct sample rate. Yet I get horrible clicks and pops. I tried setting the Digimax to master, but Pro Tools said that there was not a valid external clock and reverted to internal. Any advice on what to try next? Shawn
C. Shawn Eib Owner, Sounds Like Audio, LLC facebook.com/soundslikeaudio [email protected] Providing recording, mixing, and post-production audio services, as well as consultation and both on-site and remote pro audio tech support. Shoot us an email for more info! |
Re: Problem Syncing Digimax FS with 002 Rack
Only ONE lightpipe cable from your Digimax output to 002 ADAT input. Set DigiMax as master.... sample rate no higher than 48k.
Set PT to sync on optical/ADAT. |
What if I wanted to use the 002 as the master clock? And can I only have the extra inputs, not the extra outputs? Furthermore, when trying to set the 002 to use Optical for its clock, it either says invalid clock source, or it lets me do it and then loses communication with the hardware every couple of minutes. Thanks!
Shawn
The 002 HAS to be the SLAVE. It won't work otherwise.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
I'm using the FS with a 003 - works great! And trust me... you want the 002 as a slave and the FS as a master - the FS has a much better clock and will improve the sound of the 002 or 003 a lot!
Michael
___________________________________ Pro Tools 2021 Ultimate - Native, Mac Pro 2013-3.5 ghz, 6 Core and Macbook Pro-15"-i7, 2.2 GHz UAD Apollo 16, UAD Apollo Twin Quad, Aphex 1788 Mic Pre's (16 channels), Presonus Digimax-FS, Hear Technologies Hearback, Dynaudio BM5A and BM9s Sub. |
You are not setting the sample rate on your Digimax the same as your PT session. You have to do this manually. Not above 48k either.
Nobody on this forum can help you if you don't give enough information. |
HELP!!!!003 not syncing up with ADAT Digimax LT! HELP!!!!! | BTGR&P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-16-2007 06:44 AM |
002 Rack not syncing to MTC | DrRinse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-07-2006 10:25 AM |
Routing question - Mic pre, Digimax LT & 002 Rack | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-26-2006 06:23 AM |
Octopre LE vs. Digimax LT with a 002 Rack | Ken P | Tips & Tricks | 13 | 06-04-2005 06:05 AM |
Using a DigiMax LT with 002 Rack | 72reissue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-21-2004 12:56 PM |
