Old 11-23-2006, 09:20 AM
LSW LSW is offline
Default Record enabled tracks, setting levels
Back to the basics here - I record enable a track, select the appropriate input and can see the meter and adjust the level accordingly. But when I hit play (not record) the meter input doesn't display. I would like to set the level while the song is running, but can only see the meter when it's actually in record or stopped. Is there a workaround or setting for this?
Old 11-23-2006, 10:18 AM
Third Eye Studios Third Eye Studios is offline
Default Re: Record enabled tracks, setting levels
"Input only" monitoring (alt+k) will do just that. It's in the "track" menu in PT 7 or the "operations" menu in PT 6.
Old 11-23-2006, 11:11 AM
LSW LSW is offline
Thanks - are there any disadvanges to using this? Will it disable monitoring direct from the MBox as it implies?
Old 11-23-2006, 08:05 PM
This is not the monitoring mode to be in when doing punch ins, becuse you won't be able to monitor the pre and post punch-in signal.
I'm not sure, but if I were to guess I'd say no.
No output on Record Enabled Tracks Headlow Pro Tools 11 2 07-24-2013 10:32 AM
Levels fine, record-enabled, not recording, please help dngillespie Pro Tools M-Powered (Mac) 1 04-03-2012 11:39 AM
Levels fine, record-enabled, not recording, please help dngillespie macOS 3 03-03-2012 09:11 AM
Setting Record Levels GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-29-2007 11:37 AM
Automation on record enabled tracks Klaus Badelt Pro Tools TDM Systems (Mac) 0 01-19-2000 02:22 PM
