Old 10-03-2006, 06:10 PM
Jim Toscano Jim Toscano is offline
Default Presonus Digimax connected to Digi Rack 002 help
I have been using the presonus digital preamp with my 002 together for 6 months with no problem, now I have a clocking issue. Rapid clicks and pops.
Digigmax set to 44.1 khz
Digirack 002 set to 44.1 khz
002 Hardware setup is as follows:
Digital input: RCA=S/PDIF , OPTICAL= ADAT
CLOCK SOURCE: INTERNAL
SAMPLE RATE 44.1 KHZ
I changed the cable.
What could be wrong
Thanks Jim
Old 10-03-2006, 06:56 PM
lemix's Avatar
lemix lemix is offline
Default Re: Presonus Digimax connected to Digi Rack 002 help
Jim,
What could be wrong
CLOCK SOURCE: INTERNAL >> ! You must select clocking from the Digimax ( SPDIF or ADAT depending on the box and connection method )
Good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 10-03-2006, 07:43 PM
Thanks. When I select ADAT as clock source 002 tells me clock choice is invalid reverting to internal.
I thought clock source was supposed to be set to ADAT.
Im using a lightpipe connection from digimax optical out to 002 optical in
Thanks
Jim
Old 10-03-2006, 10:44 PM
Matt Whritenour Matt Whritenour is offline
is your adat cable going to the ADAT input of the 002r and not the output?
www.klarityrecordingstudios.com
Old 10-03-2006, 11:45 PM
Ronzelle Ronzelle is offline
The 002r clock source has to be set to ADAT. The session should restart after you change the clock source from internal to ADAT.
Your other setups seem correct.
Make sure the Digimax is not set to external clock source.
Saylah.com
Ronzelle
Old 11-23-2011, 09:20 PM
uphillstudios uphillstudios is offline
I know I'm about 5 years late but when you open your session make sure you are in 44.1 as well. When the clock reverts to internal it usually means either your session is in a different rate or your digimax is at a different rate...assuming your cabling is correct. Use your digimax as the clock source and you should be good to go!
pt 10 digi 02 and presonus digimax lt javier gil macOS 1 12-21-2011 04:13 PM
PreSonus Digimax 96k and Digi 003+ and conflicting sampling rates uphillstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2011 10:38 PM
Connecting 003 Rack to Presonus Digimax LT via Pro Tools LE 8.0.5. Help DiscoBilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-09-2011 08:59 PM
Digi 002R and Presonus DigiMAX FS gmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-27-2007 02:54 AM
Digi 002, PT7.1 and PreSonus Digimax LT problem Arlo West 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-14-2006 03:36 PM
