Auto switch plugins between native and DSP?
Is there a way to take a session created on a native system, open it on an HDX system and get all the plugins to switch to their DSP versions without having to do it one at a time in each individual plugin window? I'm using PT 11.2 HD with HDX.
In TDM there used to be a button that allowed you to switch, but it's been awhile so I can't remember exactly....
That and a few beers before the all star game have given me temporary memory problems... :)
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 07-15-2014 at 04:26 PM. Reason: yea i ll have another |
Re: Auto switch plugins between native and DSP?
I know how to switch each individual plugin via the button at the top of the plugin window. What I'm hoping for is some way to do it globally to all plugins instead of needing to open up every single one.
Don't know if it's feasible, but if you could create the session on an HDX machine with the desired DSP plugins, I believe you could then go back and forth without having to change anything.
But since I have only used native, I'm not sure if that's correct...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
I don't think there is a auto switch, been looking for it myself. Protools should do it on it's own as the session loads... Strange that it doesn't do it for all DSP plugins.
On a TDM system in preferences>processing there is a check box 'open unresourced DSP buttons as native'. If this is unchecked when opening a native session all plugins automatically get switched to TDM if the plugin is available.
Don't know if there's anything similar on HDX but that's where I would look for it. |
I think that setting still exists but I don't believe it does what you claim. It simply takes any DSP plugins and opens them as native if there isn't enough DSP power left. It doesn't change Native plugins that were created on a non-HDX system and resource them to the DSP card. Same for TDM. That setting doesn't load the TDM version of the plugin, it only loads the RTAS version if there isn't enough DSP for plugins that were originally selected to be TDM.
Auto-Tune 7 Native (AAX, VST) | krazylain | Buy & Sell | 2 | 02-24-2014 04:13 PM |
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
FS: Auto Tune 7 Native | ejwells | Buy & Sell | 2 | 11-28-2012 12:27 PM |
Auto conversion TDM - Native when DSP is unavailable | Dizzi45Z | Pro Tools 10 | 0 | 12-07-2011 10:05 PM |
Auto-Tune Evo Native offer - Compatibility | Mike Borok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-18-2010 02:51 AM |
