Re: 11.1.3 -9173 every time you insert a 3rd party plug question.
Not yet. This is a known issue and a bug with Avid. I have been working with them, sending reports, etc. I have a 2011 MBPro non retina with no issues, same exact setup on a 2013 MBPro retina with issues. It will get resolved I am sure...
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
Try to also delete all Avid plugins from the plugin folder. Re-starting PT11 will re-instate latest versions of the core plugins (if you haven't hacked the PT11 application like I always do). In case some plugin wasn't replaced and is wrong version...
I'm running on a trashcan Mac Pro. I'll try deleting the plugins and see if that helps at all.
Composer/Sound Designer Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909 HD Omni/Thunderbolt Native A bucketload of libraries www.Reverbnation.com/jedediahjenk www.soundcloud.com/jedediahjenk notedmusic.wix.com/jedediahjenk |
I don't use native plugins and I get the message to remove them. Plus I can't bounce in real time at all. my offline bounce works, but only at 1.5x speed. I use all UA pluging with 12 DSP processors. I get the 9173 message constantly at 2% of my cpu usage. I give up !!
Imac I7 quad core Mavericks 16gb ram UA Apollo quad core thunderbolt UA Octo 8DSP Thunderbolt Protools lastest version |
#16
Dang. Sorry to hear people still having issues. Both of my rooms are now OK. I had wicked RTB errors with 9173. Not in either room after update.
#17
The OP noted that the problem occurred when he inserted a new plugin with the transport running.
As musicman691 previously noted he also had problems when inserting plugins with the transport running. I can see a whole lot of reasons why inserting plugins with the transport running would not be good practice and could result in errors. You may draw your own conclusions, but I consider good practice includes stopping the transport before doing anything other than adjusting parameters on a previously inserted plugin...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
#18
+1 We never instantiate a Plugin or a VI while a session is running as its like asking for trouble. I know we have got away with smaller plugins like some waves and one off stuff but we never been able to do that with UA or softube and PA etc. I don't think that computers are built to do all the things they do while running the most complex and BIGGEST CPU using DAW and also be able to load up large plugins like Slate or UA etc while playing back streaming audio. Why is it soo bad to stop a second and start again when you loaded up the plugin you wanna tweek in real time? I don't think that Avid sees that as a "Bug" as it's never going to,work on a normal Spinner drive. Those has to read and write at the same time and having that work with a whole session while inserting large CPU hungry plugins while running is just too much for a spinner drive or a 50-60% used SSD and seriously doubt they will "fix" that. Too many computer configurations for testing and supporting this unless we all use SSD only. Then it works "Ok" here to load plugins while PTHD11 is running but we get a small drop out of sound for a 0.5 sec or so. It's not a big issue but I would never ever try with a spinner drive as thats not gonna work great.
#19
Yeah I think that practice was used primarily during TDM days.
I think it was more common with TDM, but native always had audio dropouts No errors but audio dropouts
#20
Not just dropouts but noise spikes and loud pops in the monitors when inserting plugins with transport running.
Cut/Insert Time - workflow question | zakco | Pro Tools 10 | 10 | 07-11-2012 12:30 PM |
Insert Time playlists question | summit01 | Pro Tools TDM Systems (Mac) | 1 | 10-03-2009 07:41 PM |
insert plug in question | billybroadsword | Pro Tools TDM Systems (Mac) | 5 | 05-15-2009 08:38 PM |
Time & Pitch plug-in question | dillyllama | Tips & Tricks | 3 | 09-09-2006 07:35 AM |
How to insert time / insert measures, without upsetting tempo map and markers | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2003 05:45 PM |
