Old 01-03-2018, 01:32 AM
espron espron is offline
Default MC control unresponsive rotary knobs
Hi, I am seeing a strange behaviour on my MC Control.
Sometimes, when I try to control parameters the knobs seems sluggish. However controlling the same parameters from my MC mix always works fine.
And here comes the strange part: If I start controlling parameters using the knobs on the MC mix first and then open the same parameters on the MC Control, the MC rotary knobs work perfectly.
I have tried doing a hardware test, and all the rotary encoders both on the MC Control and the MC mix responds as expected, and there is no difference between them.
Is this a Eucon or firmware problem?
IMDB
Command 8 send mutes rotary knobs Led. onepercentfree ProControl, Control|24, Command|8 0 01-30-2016 05:12 AM
A way to control EQ (Equilibrium) parameters with the 8 Rotary knobs grfrgr Artist Series 4 03-11-2014 03:20 AM
Rotary knobs on my c/24 are malfunctioning panni ICON & C|24 0 05-24-2013 09:50 AM
Faulty rotary knobs in Procontrol audiwiz ProControl, Control|24, Command|8 2 03-29-2010 04:28 PM
flip of plug-ins rotary knobs, is it possible? Enrico Donner ProControl, Control|24, Command|8 10 03-03-2004 11:53 AM
