Damaged Hard Disk
My HD keeps getting damaged when i insert a CD (free sample CD with Future Music) which contains wav files and audio.
I open iTunes, and go to play an audio track and BANG! I get a damaged HD...have to run diskutility first aid sharpish...this keeps happening. I can drag the sample wav files off the CD and use them in PTools, but i am wondering if anyone has any advice? Seems to be a constant problem... I am using Flat panel iMac 700/ OS9.2.2 /640 ram / Mbox LE 5.2/ Pro Tools is running fine...this is more a mac problem, but i thought some of you guys may have had a similar problem if you have one of these damn iMac's and similar extension settings? |
Re: Damaged Hard Disk
Patient: Doctor, it hurts when I do this...
Doctor: Stop doing that!! Copy all needed files to your HD, and don't ever put the CD in your mac again.... Sean |
Maybe the disk utility is not fixing the problem. Try Disk Warrior. Or best bet...do as sean shannon says.
ssd hard disk or classic hard disk to install pt9hd? | hart07 | Pro Tools HDX & HD Native Systems (Win) | 4 | 10-21-2012 07:13 PM |
Hard Disk With PT 8 | DCstudio10 | Pro Tools M-Powered (Win) | 1 | 06-05-2009 09:03 PM |
Recovering a Possibly Damaged Disk? | AVGuru1 | Storage Subsystems | 0 | 01-03-2005 07:34 AM |
Help! Hard Disk attached to Disk I/O will not mount. | di.vo | Pro Tools TDM Systems (Mac) | 1 | 04-29-2001 10:32 AM |
Parallel hard disk from difference disk i/o ends? | alfred | Pro Tools TDM Systems (Mac) | 1 | 11-03-1999 12:00 AM |
