Interface Device Suggestions
I am setting up a small home recording studio based around Pro Tool 9. I currently have an Alesis DM-10 Studio electronic drum set that I want to be able to assign the individual kit pieces to independent tracks via Midi (I am currently doing this with my MBox 2). I also need analog inputs for 2 guitars, a bass, and two microphones.
Based on these requirements I need an 8 channel analog mixer that has Midi. I can't seem to locate such a device with the exception of the Digi 003 which is out of my price range. It appears that the Profire 2626, or the Presonus FireStudio will handle the requirement, but I was hoping to avoid a software mixer. Even with a dual monitor setup, I would rather avoid having another open window if possible. Is there something out there that I'm missing or did I just list all available options? Perhaps a different way to accomplish this I'm not aware of? Thanks in advance. |
Re: Interface Device Suggestions
How 'bout a used 002?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Definitely a reasonable suggestion. I am always a bit hesitant about buying used gear doe to some bad experiences in the past. Given my price range (ideally <$700), I may not have many other choices.
A separate thought...is it possible to run two interface devices simultaneously? For example, a USB midi interface (Midisport or other) to handle the drums and then a firewire mixer like the Mackie 1620i for everything else?
This will not work. You can use an interface (such as 002 or 003) that can be expanded with a lightpipe preamp(like the Presonus D8). That would make for a total of 16 inputs between the 2 devices(but Pro Tools will see all 16 inputs as coming into the 002/003). A used 002rack is easily found for around $450-500. Now if you go with PT9, then Mackie has a mixer with firewire that would work fine(1640i is the model if I remember correctly).
Buying new interface. Any suggestions? | sharptoupe | macOS | 10 | 02-02-2013 12:21 PM |
REQ: Suggestions for Audio Input Device PT9 & MacOS X | lovesexy88 | macOS | 4 | 12-20-2012 04:30 AM |
Interface suggestions | Lefcopiano1 | Windows | 8 | 07-05-2012 09:40 AM |
Using my Venue as an asio device - Smaart interface | SteveGam | VENUE Live Sound Systems | 10 | 10-18-2010 08:04 AM |
interface suggestions? | jrcrain1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-04-2009 06:04 AM |
