NuBus Disk Problems
I'm having increasing problems with hard drives on my PTIII NuBus system - apparently a corrupt directory as I get bursts of the wrong audio, which sometimes goes into a loop. The only remedy seems to be to re-format the drive, however it's liable to happen again before very long.
I'm not sure if this has to be a fault with the disk, or whether it could be the Disk I/O card, ot the PT 4.1.1 software. I know this is steam-age stuff but is there someone out there who's been there and found the answer? David |
Re: NuBus Disk Problems
Sounds more like SCSI termination issues. Be sure everything's properly terminated and that your SCSI cables and connections are good.
-Evan |
Termination and connections are fine. I've struggled for years now with a variety of SCSI-related problems, and tried all manner of checks. I really need to know if the symptoms I described could be caused by faulty host rather than the disk?
David |
Does it happen with different disks? I assume so if it's been doing it for that long. How big are your partitions? NuBus PTIIIs had a very hard time with anything over 2GB. Have you tried a different SCSI cable?
Wanted: Nubus Disk i/o | ohm | Digidesign Hardware & Software | 0 | 03-21-2006 04:09 PM |
PT III Disk I/O (nubus) question? | BrianPaulMichalski | Pro Tools TDM Systems (Mac) | 0 | 09-03-2003 07:47 AM |
882 to Disk I/O cable for Nubus | pondscum | Digidesign Hardware & Software | 2 | 06-25-2003 04:22 PM |
3 disk i/o + bridge i/o (nubus) : possible ? | peterfitz | Pro Tools TDM Systems (Mac) | 1 | 03-22-2000 08:34 AM |
NuBus Disk IO anomaly | ripple FX | Storage Subsystems | 2 | 05-09-1999 08:14 PM |
