Analog output gain adjustment
I can't find anywhere that you can ajust the analog output gain. You can adjust the input. I was wondering if by chance this also adjusts the output. Otherwise, if you use the analog i/o for effects loops your return would be a a different level than your send. Anybody know anything about this?
Re: Analog output gain adjustment
In a general sense, the master faders adjust the overall output volume, of course. You may assign any track directly to an analog output, too, and that track's output fader will directly control the output.
I think your question centers around creating an analog outboard effect send and return path: Here's one way to do it that will provide a lot of flexability- Create a send on the track in question. Send that audio to an analog output. Let's say '5' for example. Create an Aux input. Route the corresponding analog input ('5') to that Aux. Now you have level control of the signal going to your analog device, and via the Aux input fader, control of the level coming back in. If you set the send to 'pre-fader' you may then adjust the 'dry' track without affecting the level going out to the analog device. By adjusting the levels of original dry track and the processed aux track, you may change the balance of the 'dry' to 'wet' ratio for the sounds you want. |
Digidesign 192 Analog Input Card and Analog output Card for Sale | MusicEngineer | Buy & Sell | 1 | 03-03-2014 09:03 AM |
HD Omni line input gain adjustment | bissodj | Pro Tools HDX & HD Native Systems (Win) | 4 | 02-02-2014 02:00 AM |
Adat output louder than analog output ? | sanzrodrigo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2010 11:42 PM |
888 adjustment for analog mixer | fifty8th1 | Pro Tools TDM Systems (Mac) | 4 | 10-06-2003 05:40 PM |
Interfacing 888 analog output with analog console | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 09-12-2003 01:26 PM |
