#41
Re: New CLA Plugin - Looks Very Cool
Andrei - I'd be curious to know what it is you notice about the sound that is different using this as opposed to the what you've been using up to this point?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#42
Apart from the workflow boost that is the bucket system, this SSL has much more character than the SSL E-Channel, I inserted one instance on every track of a mix without adding any EQ, etc and bypassed all at the same time and the difference is scandalous, lots of character and a big change in the color, something like less bass... something that sounds instantly like hard hitting rock. But that's not enough to make me buy another E-Channel, the bucket system is!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
#43
Being an SSL I wonder what knob color and is it an E or G? |
#44
I dl'd the trial version today and am going to messing with it to see how it all works. I don't have any real SSL type plugins, so this might be one I'll get...especially given the price and the bucket system.
#45
https://www.waves.com/r/xhwkze
#46
Jack, take a look, this is the influence that MixHub with all the modules on has on the frequency spectrum while the E-Channel (CLA's console is an E) doesn't noticeable change it. It is very possible that with all the modules off it still do something but my ears are to tired today for me to be able to tell, I know the E-channel does.
The INPUT module rolls the most lows, the EQ boosts a bit around 1k but you only notice turning it on/off quickly and DYN rolls less lows than INPUT.
#47
Just made an interesting discovery. You've probably seen that you can add some other plugin into a slot in the CLA plug. It doesn't appear that you can add just any Waves plug, though. Oddly, under "effects" on the pull down menu you get when you go to add a plugin in a slot, only my JJP Drums shows up. Curious. However, in the other categories (eq, drynamics, etc) I can choose from a few others, such as the Scheps Omni. That's nice if you might want to use say the Distortion off that, along with everything in the CLA plug.
But wait, there's more...it goes the other way too. In the Scheps Omni you can add a plug as well, and one of the options is the CLA. So, you could use the CLA EQ and/or Compression (the "Bluey) say), but the EQ etc from the Scheps. Nice. However, there doesn't seem to be a way to see an alternate plug in the Bucket view. Maybe I'm not seeing how to do that.
#48
As to your first observation I seem to remember the same thing when the Scheps Omni Channel dropped and some people weren't seeing all their Waves plugins. IIRC it came down to having to do something with the Waveshell and they all have to be version 10; version 9 Waveshell stuff wasn't showing. This may be the same thing. I agree the the categorization is a it strange. Here's an odd one to try - you talk about adding the CLA to the Scheps and the Scheps into the CLA. I wonder if you can add a CLA to a CLA? Assuming the computer can handle it before going into meltdown. |
#49
That would make sense. And, yes, most of mine are 9 not 10, so that may be the case. JJP Drums I got only recently, and they were probably 10, so that would explain that. Quote:
Not sure what the point would be to do that. As for CPU...yeah, as you said, its a definite CPU hog! And, as I'm on older Win system, I'm a few generations behind the CPU curve. However, I just ran it on a session I did a while back with some 70 tracks, and I put the CLA on 7 of the vocal tracks and into one bucket, and for the most part it ran okay. But when the chorus came up and everything was "all in"...then the playback stopped. Pegged out red on the meter. . I'm guessing that issue will go away once I build my new system with a more recent CPU with more power.
#50
The first time I saw the graphic name, my interpretation of the characters was "Clam 9 Hub".
Who's sure that I'm wrong?
Bob Without a song The day would never end |
Cool new multi fx plugin from Synaptricity | crizdee | Pro Tools TDM Systems (Mac) | 4 | 05-01-2006 11:08 PM |
Cool Guitar FX PLugin | Ke productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 02-02-2006 06:57 PM |
Cool Plugin Names | ThatHitSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-21-2003 05:06 PM |
Check out this cool organizing Plugin!!! | gabriel_p | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-10-2002 06:34 PM |
Cool New RTAS Plugin For Guitar Players | flashbak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-25-2002 04:03 AM |
