Out of nowhere- Pro MB dynamic outputs phasing
After using this for years in my mix template, I opened a session and the split outputs are phasing with main outputs... Anyone seeing this?
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: Out of nowhere- Pro MB dynamic outputs phasing
Some things to try:
#1-Disable then enable Delay Compensation(this has worked for others when odd phasing or other ADC issues crop up). #2-Show Delay Compensation in the MIX window and review the numbers to see if you see any that don't make sense. If you DO see any odd numbers, try disabling all your sends. If that makes the ADC numbers change at all, then you might need to adjust your routing(like; are you busing audio tracks to an AUX track, then routing that AUX track to another track). Another possible cause is having a send that has no destination(example, you send a guitar track to an AUX track with an effect plugin, then you change your mind and delete that AUX track. If the send is still on the track, but its destination is no longer there, ADC can lose its "mind" and add a bunch of ADC to several tracks. This has happened to me more than once). #3-Trash prefs and database files(always worth a try when something is suddenly not working as in recent past)
Outputs configured in I/O setup not available to select as track sends/outputs | Stuart@YM | Pro Tools 12 | 5 | 03-21-2016 07:44 AM |
Amp outputs same level as Main outputs? | DonaldR | Eleven Rack | 0 | 02-07-2013 01:50 PM |
Apogee Duet outputs better sounding than Digi002R outputs? | Pasz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-08-2010 02:19 AM |
please help on mirroring outputs 1-2 to s/pdif outputs! | ournature | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-13-2007 08:52 PM |
What's SO dynamic about dynamic voice allocation??? | jimlongo | Pro Tools TDM Systems (Mac) | 0 | 03-14-2001 02:52 PM |
