Old 08-25-2016, 11:06 AM
chrispalowitch chrispalowitch is offline
Default S6 Stuck on Initializing Network
Hey All,
My S6 console was working perfectly. About a week ago, after a shut down of the studio one night and a powering up the next day, the S6 will not complete its startup. The Master Module touchscreen is stuck on "Initializing network interface and services (this may take a minute or two)..." or in my case, 6+ days. The module screens are stuck on "Waiting for Network".
On my Mac Pro trashcan, the first ethernet port is being used for internet and connecting our Dante network, and the second is being used for the S6 controller.
In the WS Control App, I used to be able to switch between multiple network interfaces so I could select the second ethernet port, but now, it only shows the first ethernet port.
Nothing has changed in the network settings from what I've been able to tell.
I currently don't know how to update the software because the guides all start from the home screen on the master module, but I can't get there without the network initializing.
Please let me know if you need any information from me to help solve this issue. Thanks!
Chris
Old 08-25-2016, 12:04 PM
creativecontrol's Avatar
Default Re: S6 Stuck on Initializing Network
Greetings,
I would recommend contacting S6 support to expedite the process of getting you back up and running. They would need to determine the particular configuration you have established (internal DHCP via MTM vs external router) and to ensure that everything is communicating properly. If WSControl is not connected to the correct NIC and seeing an IP address in the same range as the console modules you have a red flag right there. Let me know if everything gets sorted.
S6 Support: (650) 237-1700
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-25-2016, 07:10 PM
EddieJones's Avatar
This sounds like the S6 switch is either not powered up or failed. Neither the Master Module or the WS are seeing the S6 Switch.
Old 09-22-2016, 03:24 PM
polyh3dron polyh3dron is offline
IIRC this has something to do with the S6 inexplicably having trouble resolving its own IP address in a closed network. I believe if you switch the ethernet connection on the inside of the S6 from port 2 to 1 (or it may be vice versa, going off fuzzy memory here), and then on the other end, temporarily connect the S6 to your Dante/Internet network so that your router can give it an IP address and a DHCP lease. Then start it up and it will actually have an IP again, at which point you can then switch it all back to your original network connection and everything will once again be hunky dory. Until it happens again, probably a few months or so down the road, that is. I've dealt with that very issue a couple times at work myself.
Old 09-22-2016, 06:54 PM
EddieJones's Avatar
If using the internal DHCP then the network adapter has to have a fixed IP and does not need to get one from anywhere. Switching from port 2 to port 1 and visa versa would require network settings to be changed for it to work correctly.
Old 09-22-2016, 06:55 PM
EddieJones's Avatar
Originally Posted by chrispalowitch View Post
Hey All,
Chris
Did you get this resolved ?
Old 10-08-2016, 08:15 AM
Llamaguy Llamaguy is offline
Just wanted to say thanks! This worked perfectly!
Dana Meeks
Audio Guy
Orlando, Florida
Avid Application Manager stuck on initializing Intransit Pro Tools 12 9 01-15-2017 10:45 AM
PT First stuck at Initializing Databases Mahkyb Pro Tools | Intro Discussion 3 07-27-2016 12:38 PM
STUCK on Initializing Audio Engine piano686 Pro Tools 11 1 03-02-2015 03:11 AM
PT HD8 - Stuck at Initializing Hardware (DSI) RoofTopLuki Pro Tools TDM Systems (Mac) 5 07-07-2014 11:03 PM
pro tools 10 HD stuck at Initializing Hardware (DSI) blujway macOS 3 05-15-2012 04:28 AM
