G5 PPC Setup questions...
Im setting up a second PT setup on an older g5 and have a couple a questions concerning the optimum setup of this 2.7ghz G5 and a PT8 HD3 system.
First, is there any advantage in having 8gb of ram over 4gb with PT8? Question 2 It's recommended when using a drum program like BFD, to use a separate hard drive. There are only 2 internal drives in the G5. The second drive is dedicated to PT as an audio drive. Should I be running the BFD audio content from the main drive or should I use an external USB drive for BFD? Thank you! Chris |
Re: G5 PPC Setup questions...
Finally, don't neglect your backup solution.
--Jeremy |
I put an extra drive in on the dvd buss and didn't come across any problems (tho' not sure if you're meant to!) I was using it for sample storage/playback so that might be an option for you...certainly saves on space Also. personally speaking. I've been running both my G5ppc systems with 4gb or less with no noticeable hiccups either but I'm sure more ram can't hurt. |
I've been running PT also on my g5 2x2 with only 4 gigs ram with no problems with FireFox, Acrobat and a number of others running.
Thanks guys!
PT 10.2 setup questions | Ferrante | Pro Tools 10 | 5 | 08-04-2013 02:36 AM |
Few Questions for new Setup | ChrisIanSmith89 | Pro Tools 10 | 1 | 07-25-2013 11:29 AM |
Upgrading My Setup... Have Questions | CallitSleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-18-2007 07:24 AM |
Structure setup questions | Skytouch | Virtual Instruments | 7 | 07-22-2007 07:33 AM |
Mixer Setup Questions... | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 08-09-2002 10:01 AM |
